EDIT: Sorry guys pics didn't work at first as I had no way to check.. but they're all up now
Hey guys. This isn't a definate guide, but I just couldn't wait to put them in.
Also, im not sure if everything is 100% correct (actually I doubt it), but I put them in and they work... Also, this is for the H1 kit installed on a R33 GTST S1 Skyline, yours may not be exactly the same, but I guess the theory would be the same. This is from the Bankids group buy.
First take out the old globe assembly. The dust cover just screws off and the old globe is clipped into place. You have to make a small cut in the dust cover to push the wires and grommet out of the dust cap backwards so that it can be 'modified'. 'The Modifier' is my tool of choice, makes easy work of the plastic.
post-10683-1131848800.jpgpost-10683-1131848848.jpgpost-10683-1131848894.jpgpost-10683-1131848937.jpg
Basically we want to make room for the HID assembly and grommet attached. I used a 25mm hole saw drill bit thingy, but cut it however you want. Basically the hole must be about 25mm or 1inch if your american.
Be carefully with these and be sure to always wear appropriate safety equipment as shown in the picture. Once you cut the whole for the 25mm grommet, drill another hole with a 8mm or similar drill bit. It should look something similar to this after (but hopefully neater).
This is for putting the original wires into the sealed chamber where it was before.
Once these are pushed through and you can confirm that its pretty well air tight, crimp the old connectors to the new HID connectors, they were a bit of a different size on mine, but just make do.
I found that if your working on the wiring, the best bet is to put the HID globe back into its cannister so that it doesnt get knocked around also apparently you cant touch the glass of the new globe as it will create hotspots and decrease the life.
Once this is crimped, best to put a bit of electrical tape around these connections so that + doesnt touch -. If anyone has any better suggestions, do tell, but i'd say this would be the best bet. Next put the new HID globe where the old one sat previously. Screw the dust cover back on and that light is done.
Basically the other light is the same. I found that the drivers side is a bit harder to get to because of the washer bottle, but the air filter side (if you have a pod) is piece of piss to get to.
Once these lights are mounted, the next thing id suggest is to mount the ballasts and relay/fuse wiring. I put the relay/fuse wiring just to the drivers side of the radiator as there was a pre drilled hole so I just cable tied it to it, also it gave me enough length in the cable to stretch across to the passenger side lights.
The relays/fuse basically have 2 wires that connect to +12v and 2 wires that goto Ground (-). I ran my positive cables to the fuse box where i saw a + terminal screw, which I just screwed to the top of. The negative cables I just used the screw that was holding my strut brace on because it is earthed to the body.
I ran the relay/fuse cabling across the underside channel in front of the radiator and cable tied using existing pre drilled holes.
Make sure that you mount the balasts to the plate provided, im guessing this is because the balasts cannot be earthed, and a plastic set of grommets seperate them. I used the screws/bolts that came with the back to mount together. Then the backing/mounting plate can be mounted to your car.
I mounted the ballasts near the strut towers on either side, but i guess you can mount them anywhere you like as long as it doesn't interfere with anything, is pretty safe from the elements and you have enough cable to get to the lights. The drivers side again mounted to the strut brace bolt, and the passenger side to the air filter bracket (if you have a pod that is)
This is a pic showing you the difference between the light, disregard my headlights, they're faded to hell, I have to polish them tonight :huh:
I hope this helped some of you anyway. It's a work in progress... Let me know if I missed something or you need some clarifcation. Plus.. i headed out last night and tested them, they are bloody bright, very white light. I would definately recommend a H1 6000k set of HID's
https://www.sau.com.au/forums/topic/94635-r33-hid-light-kit-install/
  • 3 months later...
  • 2 months later...
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
