Hi All,
It's been a while since I posted something on this forum.
You may recall I had an r33 gts-t ser 2 and then upgraded to an Audi S4, thoguht I would show you a few updated pics, and mods I have done so far:
Old Car:
Didn't have much in the way of mods (fmic, turbo back exhaust, upgraded clutch, GTR rims, Power FC, 040 fuel pump - 190 rwkw's)
New:
Mods so far: - H&R C/O's, Whiteline rear sway bar, dual port BOV's, Borla exhaust, Potenza RE070 semi slicks, Defi Bf boost gauge, Samco hoses, RS4 19" rims, GIAC chip, DBA 5000 light weight/slotted, EBC Greenstuff, 5mm spacer
Edited by Robo
https://www.sau.com.au/forums/topic/94644-update-on-audi-s4/
personally i don't see the S4 as an "upgrade" as such but hey..... that's just my opinion... nice car btw
your a weirdo.....
Class, power, style, AWD and the 0000 on the front...... that is damn sure an upgrade...
Always loved the look of this car mate... keep up the good work!!!!!!!
your a weirdo.....
Lay off the sugar and read my post
haha,
It's funny cause I only had it done that weekend.. News travels fast.. :D
I have to know who it is.. This is killing me hah
nice car dude, still factory turbos? k03s or k04s? i thoght they are tiny arent they? hence need 1.6 bar. how about a pair of gtss for an upgrade B)
Edited by GT Skyliner
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
