Importing From England
Just in the UK at the moment, and yesterday hired a turbo diesel peugeot. It was a new car with only 2000 miles on the clock and man I was impressed with the performance!
Not as good as my r33 of course BUT it only used 15 litres of diesel for 198 miles of spirited driving! I didn't believe the trip computer when it said 58.5 miles per gallon but at fuel up time it was comfirmed.
So I was just interested in if anyone has looked into importing cars from the UK or do it at the moment? Also I haven't ever looked at turbo diesel cars available in AUS - it's not a thing I've ever been interested in. Just that cars depreciate in price very quickly in England - 2-3 year old cars go for 80% less than when they were purchased new.
With the way that car handled/drived I'd have no worries having it as a daily driver - the modern turbo diesel comes onto boost at about 1600 rpm and you can be really lazy, chugging along in a higher gear than normal. Taking off from lights is effortless and you leave a lot of similar sizes petrol cars for dead.
Anyway - I'm interested in what other people have to say!
Cheers
Sounds like a great little car, I don't mind Pug's well built units.
As for the Uk import scene terminal rust (chassis) is usually the biggest concern. But with late model cars like the pug you mention it wouldn't be an issue i'd guess...still I'd be looking underneath anything I was considering very closely.
we've imported a few cars from England for clients... only really good for specialty cars though. Plus most of the newer cars can't be imported as they either don't meet SEVS requirements or are already sold locally. If the car is built before 1989 then it can be done, shipping is a little more expensive than from Japan, but other than that the process is virtually the same.
Yeah I'd never purchase an old car here.
I was just impressed in how easy the car was to drive. I'd love to go for a drive in a new VW tdi golf - I've heard they are pretty quick.
A lot of European manufacturers are releasing their diesel models in Australia these days, so there is probably no need to import. Even with the fast depreciation of the UK market, it probably wouldn't end up any cheaper due to the extra costs of importing. Plus compliance would likely be impossible.
As far as I know, it's only really BMW who refuse to sell diesel in Aust (except in the 4x4s), which is a real shame because I've heard good things about the diesel engines in the 1-series (122bhp, 0-100km/h in 10 secs, 6 litres/100km) and 5-series (272bhp, 560Nm, 0-100km/h in 6.5secs(!), 8 litres/100km). Peugeot, Citroen, Mercedes, Audi and a few others are introducing more and more of the diesel line up to Australian markets. If diesel is your thing, there are rumours of diesel variant for Holden Commodore (Isuzu sourced) and Ford Territory for the next generation of cars.
Just had a look online on the Australian trading post and could only find one diesel peugeot, and no VW golf diesels.
Also just had a look at the friday add here in England and there's quite a few peugeot turbo diesels going for under 3000 pounds, and one was a 2003 model! Also got a performance car magazine, and they did a performance buyer hot hatch test.
One of the hatches tested is the Peugeot 206 HDI GTI, which has a 1.6 litre turbo diesel, 110bhp,180lb/ft torque, 58 MPG - with a purchase price of 13770 pounds after 3 years it will be worth only 4900 pounds....
I did a search on CarSales.com.au for Peugeot with keyword "diesel" and got 3 private sales and 26 dealer sales. There were also 6 diesel Golfs in dealerships advertised. So they are definitely around!
But if you get a diesel, it's gotta be something like this :P:
"Headlining the offensive was the SLK's new performance-orientated triple turbo (yes, triple) 3.0-litre V6. The SLK320 CDI Vision, as it officially known, was equipped with the latest Piezo Injector technology and a trick water-to-air intercooler, which enabled the engine to produce 286hp and 630Nm of torque.
It's enough, according to Mercedes-Benz, to provide the compact roadster with 0-100kmh acceleration in 5.3 seconds, just 0.4sec slower than the V8-powered SLK55 AMG. Fuel consumption is said to average 7.5 litres per 100 kilometres on a mix of city and highway use. Translation: it's very frugal for its power."
http://www.drive.com.au/editorial/article.aspx?id=9427&vf=1
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
