I suppose however, that on a completely stock skyline, the stock intercooler would have an efficency close enough to a FMIC for the purpose of producing the power made at 'stock'. Furthermore any advantages made by lowering the charge density of the air from a FMIC would probably be outweighed by the difference in the 'lag' time taken for the turbocharger to increase the pressure in a larger area.
So in that respect Paul, I would agree with you. I wouldn't see how just adding a FMIC would increase power (unless you had other mods like exhaust, upped boost pressure etc).
I just picked up my blitz boost controller from autobarn today, f*ken whole manual is japanese, there goes the auotbarn sales talk 'it wll bolt on, just read the manual'. I ordered a Hybrid front mount intercooler kit through them yesterday as well, got if for $890 inc freight to Darwin, not too bad, could have got it cheaper but i get a local replacement warranty etc. MODS are coming slowly
When i installed my front mount, the biggest thing i noticed was the lack of throttle response. Running the same boost i thought that the car was a little slower overall.
Turning up the boost sorta overcame that problem, but throttle response wasnt there. When boost hit though, it felt faster (since i was running more boost), but from my experience with a FMIC, ive come to the conclusion that a fmic is a support part to allow you to get more power.
I still need tuning though so maybe my opinion will change after that.
So pretty much what paulr33 said is spot on.
What youll get is more lag, less throttle response and worse fuel economy, but you get the potential to make more power in the end.
my fmic is a greddy v-spl
Physics hey? Boyles Law, Charles’s Law etc.
P1V1/T1=P2V2/T2
I’ll borrow some numbers from FMIC tests for a RS500 and pick a boost of 15psi.
Turbo air temp was 135deg C. (408 deg absolute)
After the cooler the air temp is 35deg C. (308 deg absolute)
So the turbo pumps 15psi x V1 at 408 deg absolute.
After the cooler we have either 0.75V1 at 15psi or V1 at 11.3psi.
Sure there is air flow resistance in the pipework and heat soak for a sustained load, but the numbers demonstrate you get more denser air.
Most errors happen in wastegate pressure readings.
An Rb20 takes the wastegate pressure straight from the compressor housing so it doesn’t know what is happening in the plenum. It will spool up fractionally faster but now there is a lot more volume to fill so it’s a bit laggy.
Once the initial surge has levelled out, the plenum pressure will be lower than normal, but it will be filled with denser air so the net result is similar power, with a nice anti-detonation safety margin.
The Rb25 takes its wastegate pressure after the cooler, so you’ll get more air in the plenum due to the increase in air density. Again it will spool up slightly faster and it will have some lag, the plenum pressure will read same as before but it will now have a more dense air charge. The turbo has eaten more air and the AFM is out of sync with the parameters set up by Nissan.
Without altering the tune via a PFC etc, the AFM will sense the larger air flows and start to dump in fuel. Stop/start conditions are the worst as it’s continually fuelling for unrealistic air flows, the black-bumper syndrome.
If you add some other factors like a cold evening and no air temp compensation, I’m sure that’s why so many slightly modded Rb25’s experience the R&R which ends in the Ignition/Fuel cut and the poor old coil-packs cop the blame.
Regards.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
