Don't worry too much about keeping your coolant below 100 degrees. Even if you use plain water it will go a fair bit higher than this because the system is under pressure and hence the boiling point is higher. On my motorcycle, the thermo fans don't kick in until it's well over 100 degrees, probably at around 105-108. I've been sitting in traffic in the middle of summer and it will get up to around 110 before it drops, but it always drops by this point and never overheats. My previous bike used to get up to around 115-118 on the hottest days. I think this is stupidly high because it heats up your legs via the exhaust and gets uncomfortable, but apparently it's fairly normal on sports bikes.
By all this I'm not saying to aim for a thermo cutoff of 120+ degrees, but you have a lot more headroom than you think if you find yourself overheating in traffic.
why dont u guys get a thicker radiator and a thermostat that opens up at 65degrees ...with one fan and these simple mods as well as an oil cooler u should be able to keep temps down alot.....why bother with a twin fan this and that, when it is a bandaid solution because the fans wont last that long ...
That sounds far too hot to me, wouldn't some of the parts fail much faster at such high temperatures being constantly put through it? I'd be happy aiming for what the stock specifications are to be honest.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
