We are pleased to offer forum members this special offer new Autogauge Defi-style smoked face gauge bundle packs.
ABOUT THIS PRODUCT
This special Autogauge bundle package includes 3 of our new Defi-style smoked face gauges in 2 inch size, and 3 gauge DIN panel in which you can mount your gauges.
We have two bundle packages available
PACKAGE A
1 x 2 inch mechanical Boost gauge
1 x 2 inch electrical Oil temp gauge
1 x 2 inch electrical Water temp gauge
PACKAGE B
1 x 2 inch electrical Air fuel ratio gauge
PACKAGE C
1 x 2 inch electrical Oil pressure gauge
Each gauge includes sensors and required parts for fitting and blanks out completely when powered off.
These gauges and bundle packs represent outstanding value for money and are a fantastic value alternative to Defi gauges with no controller required.
We have a huge number of these in stock ready for immediate pickup & dispatch, so unlike other deals floating around the net, there is:
1. No deposit required
2. No minimum order
3. No waiting
4. Easy online payment options
5. No surprises
Deal with an established and trusted company! - Not a backyard trader
PICTURE OF THE 3 GAUGE BUNDLE PACKAGE FITTED
GRAB YOUR AUTOGAUGE BUNDLE NOW FOR ONLY $175!
(AUSTRALIA WIDE DELIVERY AVAILABLE FOR AN ADDITIONAL $20)
(NZ and TASMANIA CUSTOMERS PLEASE CONTACT US FOR A QUOTE ON FREIGHT)
So how can you place your order?
The answer is simple!
Visit www.justjap.com/parts_ngauges2.htm and purchase your 3 gauge & DIN panel bundle online quickly and easily via paypal or credit card, or drop by our Kirrawee factory and pickup your set over the counter.
Please contact [email protected] if you have any questions, or reply here.
Dont forget to check out our huge range of new and used performance parts and import vehicles via our website at www.justjap.com
  • Replies 58
Should do, best to take a quick measurement of your DIN space to confirm.
We have sold these bundles to many R33 owners and had no reports of problems fitting.
Cheers,
Steve
can you like change the gauges that are included in the package?
ie, if i already have boost and oil pres. on the pillar, and want oil temp, water temp, and 1 other in this pack, is that do-able?
Hi Dezz, give Darron a call on (02) 9545 0532 and he can work something out for you.
Regards,
Steve
We have heaps of stock remaining guys, get in quick to avoid missing out on this fantastic offer from Just Jap!
These are the 90 series gauges... any chance you might be getting the 270 series in stock??
90 series
270 series
thanks >_< i'd turn off the flashing if i knew how, btw.... it's making my epilepsy play up!
(Cross posted on NissanSilvia forums - thought others might like to know)
Edited by Beeble
We have the smoked studded face gauges with 270 degree dials in stock however they are dearer than the gauges we are offering as part of this promotion.
If you are after those ones in particular, we can put together a package deal for you
Regards,
Steve
Would these fit into the factory space in the center of the dash on a R34 Gtt. If not, do you know what will. I think the HPI R34 used aftermarket ones but I'm not sure what make or size they were.
Cheers
Cheers
Hi mate, we havent fitted the DIN panel to R34 GTT's as yet, so best to measure the size of the space you wish to use to fit the panel just to confirm if it will fit.
Steve
Hi Alex, the DIN panels are $29.95 and you can please your order online via our website
http://www.justjap.com/parts_ngauges.htm
They have tabs on the side for fitting
Cheers,
Steve
Thanks for all the orders guys, plenty left in stock ready for the Christmas rush!
Order online now!
http://www.justjap.com/parts_ngauges2.htm
Cheers,
Steve
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
