I had a run with an R33 GTR and it wasn't any faster then my car. It was from about 60 km/h so four wheel drive had nothing to do with it. Hit 160 and he didn't pass me.
I've got a R33 GTS-t with full exhaust, Pod filter, big intercooler running nearly standard boost.
The GTR looked stock standard with an Exhaust tip...
Does this sound right?
https://www.sau.com.au/forums/topic/9475-gtr-vs-gts-t/
okay lets way up the differences
Gtr= Twin Turbo
Gtst = Single turbo
hmmm 1 difference and i already see that you gonna have to be running one not so big but decent size powered puffer to be keeping up with gtr?
and if it was a gtr man is he a shit driver!
no offence dude
but this was prolly gts-t with gtr badge
kinda like non-turbo supra drivers driving around trying to drag as if they own a twin turbo supra!
adrian
https://www.sau.com.au/forums/topic/9475-gtr-vs-gts-t/#findComment-143492
With a genuine 180rwkw a GTS25t will @ the least match a standard R33 GT-R on a roll, from a standing start forget it if the GT-R driver can launch.
A stock R33 GT-R is ~175-180rwkw on the average DD dyno & weights over 100kg more than a GTS25t.
I've put quite a few lengths (~5) on an R33 GT-R V Spec (exhaust/filters & boost increase) from a 70km/h roll to the top of 3rd, he went first. The driver of the GT-R & I spoke after the run. He was in the same gear as me & didn't stuff up. It was an honest run. Then again I wasn't exactly stock @ that stage.
https://www.sau.com.au/forums/topic/9475-gtr-vs-gts-t/#findComment-143703
If its modded enough a GTS-T could theoretically win... but it would need a fair amount of mods and be getting good traction and be a good driver. It still comes just down to rwkw
Sounds like either not a genuine GTR or he was just toying with you - most GTR owners i have seen on the streets drive very slowly...mainly 'cause i think they can't afford to insure it after spending all that money.
https://www.sau.com.au/forums/topic/9475-gtr-vs-gts-t/#findComment-143757
    • You need to jam something inside it to stop it collapsing. A washer, a spacer, a something. Needs to stay up at the fully pumped up height. I still say you can measure centrelines with a collapsed hydro lifter. Whatever max lift is will be max lift regardless of the state of the lifter.
    • Yeah, I've been watching him since the first 4 posts all arrived.
    • Quick update Guys , managed to get the water pump replaced . I first my mechanic went back and forth with Nissan AU (4 weeks) and they weren't much help, at the end they noted something about not supporting imports. So I soured the part myself from Japan. If anyone has similar issue here is the part numbers  Genuine Nissan PUMP ASSY-WATER - 21010-4HK0E Genuine Nissan Gasket - 21014-4HK0A  Cost me about $230 including shipping (I had in within 10 days thanks to Blackhawk in Japan)  They are basically the same as the Red Sport or even the new Zed - here is link to a supplier in US who helped me confirm the parts matched  https://www.z1motorsports.com/water-pump-fan-and-thermostat/nissan/oem-14-20-vr30ddtt-water-pump-p-10167.html You can change it yourself if you like , but I had my local workshop do it , it was about 5 hours of labour.  Cheers  Pac
    • +1 for these guys, they just made me a custom muffler for another car (old Merc V8 not a Skyline) and they are legends to work with and do very nice work at a reasonable price.
    • Alright well now I’m confused, some people saying yes and others saying no. How would I modify my hydraulic lifter? Iv already pulled them apart to clean them so I know how to do that but what would I change inside the lifter to make it solid? And how would that work with clearance between the lifter and the cam?
