  • 1 month later...
Hiya, I'm in Adelaide, and know of some import places that have 'em, but they're
asking the Earth for 'em (hence, they're still sitting there!)
One's at Adelaide Fours and Rotaries, they're looking for around 500 for it... :)
With the amount these people are after for used 15 year old bumpers, why wouldnt
we go straight for FRP or A/M bars? I know 'Viva Garage' (in Adelaide) do a really
nice front bar for $350, not that Vertex / BN style like EVERYONE has, but
something different.
I think www.carmate.com sell a GTR 32 Style front bar, but again, they want
around the 500 mark from memory. But I guess thats slightly better cos it's new,
but slightly worse cos it won't be as easy to fit as a used one...
Damned if you do, damned if you don't! :huh:
Anyway, hope it helps.
Adrian.
No offense flyer but one reason you may not be getting overwhelmed with responses is simply due to budget. $300 for the bar AND lip, assumedly you want it in top condition ( doesn't everyone?), have a colour preference, etc etc
I have a black GTR front bar and lip in excellent condition, which I can do for $500 delivered to your door, and its the genuine thing, so no need to worry if it fits, drive back and forth to inspect, so on and so forth.
Let me know if this is of interest ( PM) and I'll get it to you ASAP.
cheers,
J
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
