Willowbank 16th And Streetcar Shootout 19th?
Hey all,
Taking blacky out on wed night for some final shakedown passes before its first even at streetcar shootout on saturday....
Neone else going out...
Gearbox should be sorted, so fingers crossed it may carck an 11.
See yous there.
Hi Mate
yeah
Im there on weds getting some practise. also going for some low 11s.
i have some dead street rubber tho, so we'll see. im sure no traction will be an issue for me.
I presume you are in the All in 4,6,8 rotary DYO Street Class at the StreetCar Shootout?
hopefully we should line up against eachother on weds and have a larf.
thanks
Mick
Haven't been to one for  a while might give it a try I am still a 1/4 mile virgin
Well then, no better person than Mick to give you a raping for your first time.
Just remember, dump the clutch on the last orange light....that's the one just before the green. This should give you a good reaction time.
And when you think you have crossed the finish, keep going for a bit....the track is a lot longer than you think and when you think you are finished you usually still have 100m to go.
i will probably be heading out
as i just got my power fc in and put the boost up to 10psi
im guessing its going to be fairly busy, considering the shootout on saturday. last quarter run was 14.3, skidded all first
i want to let the tyres down abit but i dont really want to drive on 25 psi to the next petrol station. As i just got the tyres last week
it might not matter but oh well, i'll just have to try and control not skiddin as much at the start.
Good to see a couple of skylines headin out though, last ones i been too there has been a shitload of commodores and fords.
Ya kinda guess it though being in ipswich.
Anyway see yas there, hope yas pull some good times.
hehe ive driven to the closest petrol station on 14psi before.... 25 wont be a problem....
hay jhon what to meet up and drive down
Today or saturday??
I still have some last minute things to finish off on the car, then i have to throw it on the trailer so im not sure what time ill be leaving this arvo.
Ill probably be leaving around 6-630ish on saturday morning.
i might have to look into gettin one of those compressors
could come pretty handy later on
I left my tyres alone tonight
ended up doing a 14.089
reaction .654
mph 101.69
60ft time was 2.246
f**ked the start abit didnt have much revs .
and also let third rev out a little too long.
thought it was alright though.
getting closer to getting into the 13's
hmmmm well i had an interesting night.... didnt get out till like 7:15...
Did a half powerr lass to make sure it was gonna change gears... next pass i stalled it up and it skipped foward through the beams on the front runners.... Never driven with them before... Then it managed a reasonably clean 12.2@112mph... gearbox is shifting unreal.... really happy with that.... just got look at being super consistant now.
nice well done.
i didnt have much chance to come say hi - i had sme small probs etc.
i saw a little burnout from you etc.
i ran a 11.91 @ 118.89mph lots of traction loss etc wasnt a full flat stick run.
but on other runs was having probs cog swapping...
need to change gearbox oil today/tomorow for sat.
got stuck in 2nd gear! :D
mick
    • Get a timing light on it and verify it's sparking reliably at a sane ignition timing. Use a COP extension lead to be 100% sure about timing instead of hoping that the timing loop on the back of the engine is accurate. Make sure it's actually injecting fuel. MAF is not used on the stock ECUs for initial cranking.
    • RE5R01A is the transmission. Didn't realize they had a 5 speed for the NA cars but for some reason the turbo engines stuck to 4 speeds. Looks like the solenoid block is still available from Nissan directly at a somewhat reasonable price: 31940-60X01 https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/skyline/er33/6568-rb25de/trans/317 I would move sooner on this than later. The moment the de minimis exception for Japan goes away expect to be paying 25% tariffs even for stuff like this.
    • Only RB26 are low from factory. And even then the ECU actually want high impedance, because it's essentially the same ECU as the RB20 anyway, and thus they have a f**king resistor pack!
    • Is this preventable by priming the system with external oil pressure? I've seen the speed academy folks hook up an external oil priming system to the oil pressure sensor port with an air compressor to check for oil leaks before putting an engine back in a car. Something like this: https://www.jegs.com/i/JEGS/555/23550/10002/-1?gPromoCode=SPRINGINTOSPEED_APR25_5Off&gQT=1
