Hi All
what is the best way to install the Power Fc computer?
I want to put power FC computer in my gtr34 2001what is the best why to put it can I put it alone with out the original car computer or like the Z350 I have to but it with the car computer .
Thanks
Shwaier
the powerfc is full stand alone and not a chip replacement. you simply remove your old computer and replace with powerfc, no need to swap chip sockets or anything
Ya I know its a stand alone computer put I her from my friend have a Z350 when you want to install the Power Fc on it you can put it alone put the best way if you put it to the engine and the electronic things on the original computer .
And I think there are different between the R33 and R34 because the R33 you remove the original and put the Power Fc alone .
Thanks paulr33
Shwaier
sorry i dont understand exactly? The apexi powefc is complete stand alone. you no longer need to retain the stock ecu in the car, the powerfc runs all the factory sensors and systems correctly. there would be no need to keep the stock ecu installed or piggybacked. apexi do not make the powerfc for the 350z so he/she may have an ap engineer unit (didnt know they existed for 350z) or some other form of piggyback, prehaps apexi safc?
the bnr34 skyline has built in security in the cars key to prevent theft.
i believe this works fine as its not linked to the ecu itself.
i know of at least one bnr34 skyline that has no issues, again assuming he is using the standard key still. perhaps just try it and see how it goes? let us know and ill to powerfc faq
I have a series II bnr34 and i have a power f/c , just pull the stock ecu out and install the power f/c .
No problem with the immobiliser , it has its own computer that enables the cars main ecu .
I dont want to tell you on here how it works but if you want to know pm and i'll tell you .
i think, he thinks we dont realise that bnr34 and bnr33 powerfc is different and i think he thinks we don't know about the security feature built into the key. thats the only logic i can obtain from it? but yes they are different ecu's as you would expect. sounds he was just worried about his key still working which is fair enough, i would be too
dudes
i Bought the car from used showroom in japan and after i Bought
it i realise that the car computer is a R33 computer and the key is not
the orignal key (withe out security chip) its a normal key now i want to change the computer to Power Fc and i dont know what kind i have to order the one for R33 or for R34 Because my frind Says Maybe when you order thr Power Fc for R34 the security system will work again and i dont have the key withe the chip.
Thanks
Shwaier
Just in case anyone wasn't aware - the "FC" in "Power FC" stands for "Full Computer". It's meant to replace the ECU along with all its functions, in addition to everything else it does. I imagine that's the reason why you can't use the R33 Power FC in an R34, if the R34 has additional security features.
  JimX says
but the Security Features have a diffrint computer not the same ECU
ok what the different between the 2 engines its all the same Rb26 Deet
the different in the computer and the electronic thing only.
if they baypass the security i think i can but a Power Fc for R34 and i will not need the Security key because i used a regular key now (with out chip) but let say if i need to use a security key from where can i get one and where can i program it .
Thans
Shwaier
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
    • I clean my wheels every time I wash the car, I also clean the barrels, the only product I use on the wheels is truck wash and a pressure washer, followed by (inset your chosen name brand) wash and wax, time per wheel is probably 2 minutes total, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, they're also great for getting in between the front guards and body, and tight spots in the engine bay
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
