Hi Guys
I had my car at MM a while ago to get the emanage ultimate installed on the r34 GTT auto but they can't get it to work.
I decide to take my car to 101 since they are suppose to be the ECU guys in Brisbane, and they tested my E-ultimate and told me that the unit is dead, because MM didn't set up the jumper correctly (setting for Nissan car) before they hook up everything and turn on the ignition.
So FYI, find out if the workshop really knows what they doing before going ahead. E-Ultimate is pretty much like the emanage blue but with 3 times the information, so its very easy to #$@% up if not careful.
D
https://www.sau.com.au/forums/topic/94832-emanage-ultimate-is-dead/
was the unit new when u gave it to the workshop? they should replace it surely as it was their fault it is no longer working, due to bad installation
yeah, bought it from Japan brand new. I guess I will take it back to MM sometime and see what they can do. I doult they will do anything though and they charge me for the installation as well.
I've done endless installs on 34's with e-manage...did you buy the add-on to stop the check engine light from signalling when you install the ignition harness? Also did they place diodes in the igniton lead to limit the trigger voltages?
http://www.skylinesaustralia.com/forums/in...868&hl=e-manage
This show's my old e-manage blue, with a field car specific harness...the little black box is what you need to prevent errors with ignition, you can't make out the diodes on the other section.
the jumper setting alone doesn't kill the e-manages....it would take some highly suspect installation to kill one.
I've seen an e-manage appear "dead" purely from incorrect firmware.
Well, I’m not a mechanic so I wouldn't know much about it I was been told it had fried because the jumper was set to Honda Vtec instead of Nissan (don't how they can stuff that up).
The guys at 101 put the emanage blue on my car now and it works fine, so I will leave it as that for now and the E-ultimate will be setting on my desk as a nice shinny chrome souvenir for the time been perhaps give ultimate another crack bit later on down the track, when everyone is running one in their auto. ;)
I was told my E-manage blue was a dud so I sent it back to Japan under warranty and when I got it back, I was told that the software the tuner was using was too old (I actually supplied them with new software and they didn't use it!) and my E-manage needed to be updated with the latest firmware to solve my issues. Cost me $80 to fix something that I could've done myself by updating the latest firmware. All is fine with it now though.
Poor value about the E-manage Ultimate hoo@h, I remember reading about your issues with it and I was feeling the same thing after I was told my E-manage was going to be a paperweight. I don't know how they could've set the jumper for V-Tec engines either as to do this, don't you actually have to alter the jumper settings specifically for this purpose? That is, it wouldn't come set up for this from the factory would it? Have you checked the jumper settings yourself after they told you it was stuffed? It's pretty easy to do. I thought the jumper settings would only kill your E-manage if you set them incorrectly and then tried to run the car a few times. But the unit should've sent back some error messages telling them not all was good, and possibly not even started at all?
"There's very little meat in these gym mats!"
Edited by MacGuyver
yeah MacGyver is right about the firmware, this is the normal cause for the e-manage to shit itself...normally it's the ignition side that will fail to operate...it's fixable though.
hoo@h I'm willing to look at it for you if you like? Just send me the software and the e-manage and I'll see what's doing with it.
For future reference..all firmware updates can be found at www.mohdparts.com
Well, all jumper setting are listed in the user manual, perhaps they thought they had it on Nissan setting.
They did contact 101 and got the latest software, but I guess attempting to tune the car with wrong jumper setting killed it.
Anyway, I think 101 got the car running with emange blue so I am just going to leave it as that for now.
Thanks for the offer 666Dan, you wouldn't happen to be in Brisbane area are you?
This ECU can be used on R34s with Tiptronic transmission?
Can someone list the benefits of this one over say an SAFC2?  I'm currently running one and wouldn't mind looking into an upgrade.
From my minimum mechanical knowledge. :P
I had SAFCII on the 34 auto before, it was pretty good but it only works on air n fuel ratio tuning, with the emanage(latest firmware n software) u can also tune the ignition timing which will give you a bigger gain in power.
Unfortunately PowerFC don't work with the 34 auto, otherwise I would have gone that way.
Yeah I'm in Brisbane...shame the old car got stolen, could have shown you the full set-up when it was in.....it was tiptronic also.
The new one has something a bit better than e-manage now...for half the cost :(
Hey Hoo@h, you said you've gone back to E-manage blue after you couldn't get the Ultimate to work. Just out of curiosity is it possible to use the same harnesses for the E-manage blue for the E-manage Ultimate? Or do you need to buy Ultimate specific harnesses?
Hmmm not sure. I know if you were upgrading from blue to ultimate u will need to buy additional harness, so I assume it will work perfectly going backwards, just with a few wiring left out.
I haven't actually seen it yet, only talked to the guys at 101 briefly over the phone. I am hoping to pick it up this weekend, if they can sort out the misfiring problem at high boost (one or more coilpacks need replacing I think).
Dan
I hope the guys at 101 realise that if you don't use the diodes and the igniton interface module, you get a the check engine light constantly illuminate on the R34's....it doesn't effect anything, just is annoying to see.
Well, got my car back and that's exactly what I got, engine warning light is on, very annoying.
So hard is it to get the warning light back to normal, can you help me out 666dan?
btw, car made about 270 hp with emanage blue, fmic, blitz filter, exhaust and blitz i-color set at 0.9 high boost.
kewl. just orded emanage ignition signal adaptor online, so is that all I need to turn those engine check light off? 666dan?
"GReddy e-manage Ignition Signal Adapter #1 - #15900906*
(For Nissan Skyline ER34 & Stagea WGNC34)
When attaching the ignition harness neo-straight 6 cars (ER34, WGNC34, etc), this adapter will prevent the check engine light from turning on.
Attach to each igniter signal on the ECU side, as well as to the ground.
Up to 6CH
D
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
