1990 Type M R32 GTST---massive price drop $12000 as is!!!
Car looks stock with no body kit or wings but has massive amount of mods underneath.....
RB25DET conversion
2.65 litre stroker kit
Drag or Drift set up (engine makes power 3500rpm-8000rpm)
115000klms on speedo but engine only 12 months old
Work done by Garage Testarossa in Japan within last 12 months
Forged pistons
HKS TO4E Turbo
HKS cast manifold
HKS pro 40mm ext Wastegate (plumbed back- but can set up with screamer pipe)
HKS external oil cooler
HKS 600*300*75mm FMIC
HKS custom piping and fittings
HKS 256 inlet cam
HKS 264 exhaust cam
HKS adj cam gears
Z32 85mm airflow meter
HKS gear set in rebuilt RB25 gearbox
Custom dump pipe
Custom front pipe
Kakimoto 3.5 in exhaust with 5in cannon
OS lightened flywheel
OS Gikon twin plate clutch
HKS Hipermax Drag fully adj coil overs
Koyo HD radiator
Sard 550cc injectors
Sard fuel Reg
Tomei 600hp fuel pump
Grex short shift kit
Cusco front/rear strut braces
Cusco 2 way spooled diff
Cusco camber and steering arm kit
Cusco roll bars and torsion bars
Upgraged front rotors and calipers
Car is fitted with standard interior in very good condition
17by 8 17 by 9 Enkei rims 235/45 and 255/40 tyres
A mint spent on this car mechanically
Sale also includes personalised plates 'RRB25'
In need of some minor paint work ($1000 quote)-sale includes GTR front guards
My new project has arrived so this one must go.
Sale also includes 2 of 16 in R32 rims with good tyres and and 2 of 17 in Hahn 5 rims with tyres.
Air cond regassed and works well
http://www.carsales.com.au/pls/carsales/...rch_distance=25
Link above for pics
$12000 as is (which is less than the cost to build this engine)
Call Mark(In Brisbane) 0410577556
As IS means no safety cert no rego.
First to drive will buy-Very fast car
Edited by overev1
Massive price drop- $12000 as is-engine would cost more to build than asking price
Car now also has full compliance done.
Edited by overev1
Silly question, thats f**kING BULLSHIT.
I had asked a legitamate question. For the seller to prove the listed parts. What is wrong with this? Any one can say the car has this or that. And the car is an import. It is against the law for a seller to sell something, stating/ listing it is fitted with 'X' but in fact it is fitted with 'Y'. The seller can be charged with fraud and many other charges can be put ahead.
I know of some one who did such, who ended up in court and paying up thousands of dollars. Hence why i asked "Can you prove the listed parts".
It is wrong for you to say it is a silly question. Every interested party would like to know if the listed parts are actually fitted.
To the seller, I am not doubting you how ever for peace and mind, and for less hassles and suspicion could you please answer the question.
regard
Harun
Mark gave the car to me in part exchange for my GTR, (and been onsold already) so it does not matter what parts are in it but heres some of the original auction details if you can read japanese.
100000㌔でエンジン乗せ換え。腰下RB26をボアアップで、2650cc、オイルクーラー、トラスト20段。カム、HKS、IN254、EX264.強化タイベル。HKSアジャストカムプーリー。HKSフルタービンKIT TO4Eウエストゲート。HKS車高調。クスコ2WAYLSD。 鍛造ピストン、KOYO3層ラジエター、HKSインタークーラー、ニスモオイルポンプ、ニスモウォーターポンプ、燃圧レギュレター、東名フェールポンプ、コンピューターRB25現車セッティング、エアフロZ32、HKSパワーフロー、OS技研ツインプレートクラッチ、強化ステアロッド、ピロテンションロッド、キャンバーアジャスタブルアッパーリンク、275φフロントビックローター
クスコリヤアッパーリンク、ハイキャスカット、リヤ255/40/17、フロント235/45/17、パワーチェック時、370ps55㌔でした。
Edited by JASSPEED
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
