I'm replacing the oil in a R32 Viscus LSD diff, since it wasn't delivered to australia they don't seem to list the type of oil required in the books in the auto parts stores. Can someone recommend a Castrol oil that would be suitable? I say Castrol because all the other fluids are castrol and I like to keep it in the family :P
Cheers
https://www.sau.com.au/forums/topic/94868-r32-diff-oil/
If the oil isnt black and its still gold, dont worry about it, the oil that the japanese use in diffs as such is much thicker and better........but if its black yeh change it with what u think is necessary, aussie oil isnt as good.......but its easier to find then HKS diff oil or something like that
https://www.sau.com.au/forums/topic/94868-r32-diff-oil/#findComment-1713579
Well the oil wont go black in a diff, cos theres nothing to contamniate it with, but it still might be 'worn out'.
You can safely use any GL5 oil that is rated for a differential. It does NOT have to specifically be for an LSD type diff, because the viscous unit is not affected by the oil. Cos you like castrol you can use;
Castrol EPX 80W90
Castrol Multitrax
Castrol SAF-XA (Synthetic)
Castrol Syntrax (Synthetic) <--- Recommend this one.
Cheers.
Edited by Busky2k
https://www.sau.com.au/forums/topic/94868-r32-diff-oil/#findComment-1713956
Where did you get the idea that Japanese oil is better than Australian. That is not true.
https://www.sau.com.au/forums/topic/94868-r32-diff-oil/#findComment-1713983
Castrol EPX 80W90
Castrol Multitrax
Cheers.
The oil in a diff CAN go black. If it has been punished it will become burnt, the more burnt it becomes, the more black it becomes.
As for Castrol oil - I would not touch the crap. I put Castrol oil in three seperate Skyline Diffs and all three developed a whining noise. One of those was my car and the whine got worse and worse until I changed it - for the third time. Castrol don't want to know anything about it because it is an Import.
I only ever recommend REDLINE Diff Oil. You should use a 90 or 140 grade. Places like Autobarn can get it for you or if you are in Brisbane, Thompson Spare Parts stock it on the shelf.
If you have to use Castrol, ONLY USE THE SYNTRAX AS SUGGESTED ABOVE. The top two listed will wreck your diff.
https://www.sau.com.au/forums/topic/94868-r32-diff-oil/#findComment-1714014
Well not everyone wants to buy synthetic so yes, I suggested the mineral oils, although I would not use them myself.
If the diff oil is going black, it is most likely to be poor quality (ie lots of oxidising), poor sealing issues, or there is lots of wear happening!
https://www.sau.com.au/forums/topic/94868-r32-diff-oil/#findComment-1719511
3lit3 if the oil is gone/punished,will you start hearing a clunk when engaging first or reverse?or does that just mean the diff is probably worn?
cheers
https://www.sau.com.au/forums/topic/94868-r32-diff-oil/#findComment-1723603
