Hi all, I am after a new turbo timer and was wondering if theres a good one to go for. I have had a bit of a search and found this one to do the job and it the cheapest I could find
http://www.nengun.com/catalogue/product/18
Is it worth spending a bit more for more features?, I don't know where I would put one of those TT units if I got one so I like the long thin ones coz thats what I have at the mo
cheers
Tom
https://www.sau.com.au/forums/topic/94887-i-need-a-new-turbo-timer/
yeah, I wouldn't need anything like that, just a normal TT that keeps the engine running for programmable times....I guess the cheaper the better for me so can I get a new TT for less than the $85 for the Apexi one I linked?
EDIT: actually it comes to $130 with shipping from Japan
hahaha... i can understand how u feel on 2nd hand parts, ESP electronics. Personally, i wouldn't go that way either, unless i'm really hard up for it and it's wayy out of my budget. And try not to buy off ebay either, some dude got a reconditioned one, that sold as new, cause when the workshop opend up the apexi turbotimer, there were burnt marks and resoldering.
no offence to RR, but I'd rather buy new than secondhand
thanks anyway though  :O
http://www.nengun.com/catalogue/product/114
Tom check if that's compatible with your car. I bought this a while ago from Nengun, sitting in a drawer & hasn't been installed. I just sit in my car for a bit, basically because you only need these when you are putting pressure on the turbo a fair bit, and letting the car idle for about 2 minutes isn't all that hard to do. Different case with 2 turbos I guess. :O
It costs $101 delivered to you in like 2-3 weeks from Nengun, $100 from me pretty much straight away, because you are just over in Beldon if you want it? It's new, in box, I opened it to have a look & that but didn't do jack shit with it.
Not talking about your penis are you? :lol:
lol :) , with that extracted from the sentence it would appear so. But no :D
ossie_21, how the hell does the shipping for that come to less than the Apexi onw which is smaller? :D and yeah, its compatible with my car
what the optional harness there?
The other thing is installing it, because I will need to tie it in with my alarm. I guess one option is taking it back to Action Alarms and get them to install it coz they tied my current TT in with the alarm when they installed it...
This timer looks bigger than it is (not another penis joke please :D ), it isn't all that big. I'm sure the same people that did your other one could do whatever you decide to get.
My turbotimer is installed with a bypass.. or rather my alarm Laserline top of the range has a bypass to allow me to lock the car while the engine is still running on the turbotimer and it'll automatically immobilise after the turbotimer dies. Which is pretty good i feel.
Thats what my Cheetah 777 alarm does, so maybe its best I take my new TT to the place that did my alarm....
sorry BNR34 I wants new :(
    • Yep, replacing all those hoses is kind of just bog standard if you're ever back there. Only hose on the back of the engine I have yet to replace is a vacuum hose for the wastegate. I'll probably do it eventually but it's in such an annoying spot.
    • I was actually just planning on replacing the fourth gear parts in the gear box that I broke … like the synchro hub or cone. And any other parts I need once I open up the transmission. That a bad idea? The rest of the gears feel tight. these parts shouldn’t be too much … just the labour here won’t be cheap. Just replacing these in HK would be around 2k aud including labour.    how much is a new r33 or r32 transmission?    thanks for the good info as usual
    • I chose a bad time to buy, at the time there was no gtst's for sale in NSW and my options were qld, vic, or sa and not the greatest examples or too far out of my budget. Ended up picking this one from adelaide sight unseen and got a bit stitched up as you could expect but i dont fully regret it, its just a shame people cant be more transparent in this day and age.
    • IMO just buy a whole R33 transmission and swap the whole thing. Use a palm nailer/air hammer with a roll pin punch to drive the shifter rod end roll pins out. The rod end is discontinued so don't break it. Use gasket dressing on the OEM paper gasket instead of RTV. I personally would not pry on the shifter cover tabs, I broke one trying that instead of just smacking the side with a dead blow rubber mallet to shock it loose from the RTV the last mechanic applied. If you can't get the flanges totally clean and free of any residual RTV and/or you might have a gap that is bigger than it should due to flange damage use RTV on that surface instead of the OEM specced anaerobic sealer. Anaerobic sealer is most likely the right sealant for the job, it's just too easy to mess it up with too large a gap or bad surface prep/roughness seemingly. If you do rebuild what you have it's for a whole gearset that can take high torque. Don't bother with OEM at that point.
    • Little hose. Big hose. They're all waiting to kill the engine.
