Hey everyone,
I am looking at maybe getting a Soarer early next year, and I was wondering if anyone knew of a good place to ask some questions? A good Soarer web forum or something would be ideal. I want information on prices for modifying the centre command centre on the V8 Ltd models. I want to know what costs I will be hit with if I decide to buy one. Mainly I want to know:
1. How much and where to go to convert the TV to Australian frequencies?
2. How much and where to go to convert the Sat Nav to Australian Maps? Else how much to add integrated navigation to command centre in non-nav equipped models?
3. I've heard you can get the system changed from Japanese to English text. How much/where can this be done?
4. How much and where to go to add a DVD player integrated into the centre command centre.
If someone could point me in the right direction that would be great. I'm only really after ballpark figures at this stage. Or even better, if someone here could answer the questions that would be sensational.
EDIT: Interestingly, Just Cars quoted me identical insurance costs ($1826) for the V8 as the non-turbo six, both with the same quoted purchase price (arbitrarily set at $18000). What's with that?
Edited by Big Rizza
I took a twin turbo Soarer for a spin before I bought the R32.
It had done 198,000kms but still drove rather well. It did smoke a little on cold start.
It was a little dougy for a fraction of a second but went quite well once up and running. It felt as if the auto would beat the dead stock 5speed R32.
It was quite nice to drive, handled well, nice and tight.
The only thing I didn't like about them was the digital speedo, kind of looked a little dated for some reason.
  • 8 months later...
Hey everyone,
Hey Big Rizza,
Did you ever find out the answers to any of the above questions - thinking about getting a soarer tt as a second car.
Cheers
It's based on how often the cars crash. For example, a Mirage costs as much as an SS Commodore to insure because they crash so often. How well the vehicle performs doesn't really come into it. I found that turbo and non-turbo R33s were the same to insure as well. This information comes directly from someone that works for JustCar.
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
