Hey guys
Last night i was driving and i heard a loud pop / bang noise and then my clutch was really loose, it was changing gears for a while and then it could not get into first gear but the others where fine and they worked normally
anyone have any suggestionss?????
as i have been refining my manual driving skills lol i think i might have ended its life,
bit of a newbie on some parts of the car
help would be much appreciated as to what you guys reckon it culd be
im pointing to a blown clutch
thanks heapss......
https://www.sau.com.au/forums/topic/94925-clutch-issues/
how were you driving at the time? would be odd for it just to go completely during normal cruising.
have you checked your master cylinder reservoir? could have blown a line.
did it go bang on a big rpm 1st gear launch?
if the other gears are working fine, you may have farked something in the gearbox...
https://www.sau.com.au/forums/topic/94925-clutch-issues/#findComment-1715222
thommo clutches can go during any sort of driving... mine blew on friday and i was probably driving along doing 2k-2.5k changes
(read: granny driving)
the sort of stick i was doing the day before probably helped hurry along the death of the clutch how ever
im thinking something like the clutch master cyl?
dont know really mate... thommo could be right, could be something in your box
https://www.sau.com.au/forums/topic/94925-clutch-issues/#findComment-1715245
thanks heaps guys
just had the mechanic look at it and he rang me
he said the gearbox seems fine but the flywheel is burnt to a crisp and the clutch is caput
so yerr getting a new flywheel and clutch :O:)
thank god nothing wrong with the gearbox
my driving wasnt too bad, but at the start it was a lil shocking
this is going back a few days, and lately it has been good
thanks heaps fellas :P:)
hope to see you on the road :)
https://www.sau.com.au/forums/topic/94925-clutch-issues/#findComment-1715494
im gonna get my mate to check it out aswell just to make sure the gearbox is not totally screwed, he wasnt home last night wen it happend, so hopefully he can let me know exactly what the problem is,
it has always been pretty difficult getting into first within 15min of driving, after that its easier........
the other gears are all fine and have no trouble
i just picked it up on friday, ggrrrr
https://www.sau.com.au/forums/topic/94925-clutch-issues/#findComment-1716864
thanks guys
but its more shit than i though, im gonna get another opinion from another mechanic i know,
i saw the flywheel and clutch
lets just say it was not pretty at all, as who ever drove this thing in japan did not change the trans oil or service the thing
they just thrashed it and dats it
https://www.sau.com.au/forums/topic/94925-clutch-issues/#findComment-1720872
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
