from the forums i thought that 20 people would be there
but what a ***n disapoitment
you r all gay
your mum smells like dogs balls
thank god for the v8's cause otherwise it was shit
thankyou for proviong once again that the drags r gay and should be shot in the arse with a elephant gun
pete
https://www.sau.com.au/forums/topic/9493-ec-what-a-n-waste/
hahaha...yeh everyone pulled out...ahh well. excuses excuses all i heard y could come...but wednesday isnt too gooda nite..
have to organise something big one day..
will try Bel Performances track day on the 17th at Wakefield :-)
(Bel, J-Racing, and Jet Speed putting together now) booked whole track hopefully for 17th
https://www.sau.com.au/forums/topic/9493-ec-what-a-n-waste/#findComment-144058
duncan
i ran a 10 flat quater after injesting a so called (hot dog) close to 400meters but can be shure all i know is that puppy stung like a bee on you **** when it came out.
the 1/4 was form my place on the hill to the nearest toilet
lucky they had that vht shit or i could have been very messy
dont worry i backed it up with a nasty dimsim that only made me run 12.5 when it came though
pete
https://www.sau.com.au/forums/topic/9493-ec-what-a-n-waste/#findComment-144110
i just hammered it from the beggining left some mad skids
60 foot was very slow casue i thought i was going to make it at first. then a i saw impending doom i had a massive MPH at the end casue i i had to be there fast
so flat ten and teh toilet need to be re-eneameled or replaced
pete
https://www.sau.com.au/forums/topic/9493-ec-what-a-n-waste/#findComment-145187
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
