hey all,
over the passed weekend i installed an intercooler kit myself in my r32. a few dramas but it went in alright. the problem now is that it doesnt feel any better, even somewhat worse. :P
after a drive i feel the end tanks of the intercooler, the intake being hot'ish and the outlet being very cool, so im sure the air is actually going through it, and theres a noticable amount more lag, but it feels asthough its lost a bit of power. i used to be able to chirp second (gts4) but cant even do that now.
that might not be the best measurement of power, but from everyone thats installed an intercooler, theyve said theres a noticeable difference, even my mechanic mentioned one he isntalled on an auto had it spinning first whereas it couldnt prior to the install.
can anyone think of maybe some common problems, something i may have overlooked, something this or that? im sure everythings on right.
shaun.
https://www.sau.com.au/forums/topic/94963-post-intercooler-kit-problems/
What supporting mods do you run? It may need a quick dyno retune if you have an aftermarket air / fuel computer.
I put a fmic on 2 weeks ago onto my Stagea, and it definately needs a retune of the SAFC.......
intercooler is not a power upgrade on its own!
sorry sorry, i also have a podfilter, cat back exhaust, (batmbl dumppipe is going on as i type this), iridiums (gapped at 0.8 if that makes any difference), running stock boost (which peaks 12 and settles at 9psi).
it feels like i had better performance with the smic on a cold night then i do with the fmic on a cold night.
s.
power comes on more gradually with a fmic cause there is more air between the turbo and throttle body but at full throttle higher in rev range u may have a bit better power but less ability to chirp so push in the back can seem less but still have more peak power
as all the others have said. when you just fit a fmic you wont gain any power or less any. but you will loose throttle response. ie: more lag in the throttle system as discussed many many times before. fit a boost controller and an exhaust now and youll gain much more than last time and response will be great too as you make the outlet system more efficient (bigger exhaust) and inlet system pump more air (boost controller)
A cooler on its own wont give you much gains however if you bump up the boost and free up some flow with some flow with an exhaust etc if there are no leaks you should really be able to feel it. Another thing is when I installed my fmic my car was running very rich this robs alot of power also, so a tune mite do you good eg safc or power fc. :(
okidokies,
well i have a full exhaust now, and it does feel more powerful and responsive (especially mid range for both), but also at the same time, feels its holding back a little.
the intercooler is 600x300c75.
boost also still drops off top end. i thought it was the stock -restrctive- intercooler that caused this. still doing it. makes me wonder if theres something restrictive in the new setup.
i might throw it on a dyno, im thinking theres too much little things to figure out by explaining it all :( :(
thanks very much for the input people, greatly appreciated.
shaun.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
