Want more power out of my RB20/2510 combo
Easy way out would be to swap a 2530 onto it, but I want to think outside the square
ATM its making 193rwkw at 1.5bar boost, it comes on real quick but looses top end
Dropping boost back to 1 bar sees 185rwkw, a tad later in the rev range
Torque is obviously allot less that what it is a 1.5 bar
Heres my thinking.
Going just by looking at the housing on my turbo, it appears smaller than a stock RB20 housing
Cubes has also commented on this, and we both reckon its pretty small.
Would it be possible to swap a RB20 or RB25 exhaust housing onto the 2510? Does anyone know how a 2510 exhaust housing would compare to a RB25 housing?
The only differance I can see on teh HKS table between the 2510 and the 2530 is the exhaust side of things, with the 2530 having a 7mm bigger exhaust exducer diameter
I just want to free up the last few thousand RPM, at the moment, changing gears at 6000rpm because you can feel the power drop isn't what I am after
I am willing to sacrifice some low/mid RPM response for more of a top end. Boost will be around 1.3bar, anymore dosen't seem sensible on a daily driven, 20,000km a year car :P
Idea's suggestions?
Attached is my last few dyno's, first one is initial setup, bleed valve set to 20psi
Second is tune at 1.5bar and run at stock boost
3rd is last dyno run at 1.5bar
AFR's are 11.5 -12.1, timing is around 16/17 degrees at full noise
My tuner suggests the turbo is at its limits, cams or cam gears etc will just make the motor more efficient and bring the turbo on earlier
I am yet to test other systems on the car, ie intercooler pressure drop, but the cooler is 600x300x60mm with 2.5" pipework all the way through. Exhaust is 3.5" dump, then 3.5" all the way to the back, no mufflers or cat etc.
Chris
Edited by Chris32
https://www.sau.com.au/forums/topic/94969-hks-2510-exhaust-housing-swap/
I can't see how swapping exhaust housings will mean it needs to be balanced
I don't really want to change the turbo, I want to see how swapping the exhaust housings will effect it.
A RB25 highflow, say a GCG 450hp or whatever they do would be good, but I want to try things slightly differantly, and I can't afford a new turbo at this point
I think with a bigger rear housing, it might be all I need
Probably the first thing you need to do is see what other housings are on the market that will fit it. As it's a pretty small turbo i would expect an rb20 or 25 stock housing (machined to suit) would be your lowest cost option (thats assuming it will bolt up to the back of the hks core).
I suspect the exhaust housings that will fit will be gt25 style though so you will be up for an adapter plate aswell
Ok cool.
I will have to do some picture taking of the rear and see what bolt pattern etc it is and then see what would possibly fit
I reckon you are right in thinking that GT25 style exhaust housings will be what will fit, so if I have to make up a adapter, by the time I do that I may as well get a 2530
Guys the main difference between a 2510 and a 2530 is the turbine itself , the 2530 uses the more open bladed 76T NS111 turbine where the 2510 uses the more oem style turbine found in the response over flow type turbos . I'm not sure if its economically feasible to rebuild it as a 2530 unless you have the turbine and Skyline specific exhausting from one . Probably easier and cheaper to buy a 2nd hand 2530 and bolt it on .
Cheers A .
