Hi,
I'm interested in front splits, rear speakers (possibly 6"..... do 6x9's even fit?) and an amplifier to power these. Later I plan to get a small solo-baric sub with a seperate amp...... but for the meantime this will do.... I guess having an alpine stacker (fm modulated at the moment) I will get an alpine headunit as well.
I'm not looking to spend much money.... Was wondering what setup everyone has??
Cheers
https://www.sau.com.au/forums/topic/950-front-splits-and-rear-speaker-advice/
Guest AFRO_BOY
Most likely 6x9's won't fit in your car coz i dont know what car has stock 6x9's. If you have a Holden you'll need to cut a hole for the 6x9's with a grinder, if u have a ford, you should be able to use tin snips, with nissans i have no idea.
You obviously know atleast some of you stuff coz those solobarics are beautiful but a bitch to power, if you plan on getting them, dont waste ur money on cheap speakers coz they make your music. Whats the point of having a good drummer without a nice vocalist.
If your gonna definitely go with solobaric or any good sub, your in for a lot of cash for the sub and a good amp. So if you spend the cash i'd say go for Infinity speakers. When using subs, always put bigger speakers in the front, so i'd say getting a nice pair of front 6 inch splits, and a pair of good 6 inch speakers, its less hastle, sounds better, easier to power.
Kicker make good amps so maybe try getting a good deal with the kicker sub and amp together.
I love american stuff which is why i've got infinity 6x9's, plan to get infinity 2-ways in the front, powered by a 50 W-RMS x 4 Clarion amp which doesn't even power em to their full potential but still good, 2 orion subs to a cheap 600 Watt amp (had a 15-inch kicker but couldn't power it well). All hooked up to a mid range pioneer deck, 5450. Reason i've got 6x9's instead of 6 inches is coz my stock speaker holes would have to be cut anyway and i got a good deal on em.
Remember, your system will only sound as good as your shittest component so use good wiring too.
Infinity splits = $350 - 500
Infinity 6x9's = $250
Deck = $500
kicker amp = $400-600
:shake: :lol:
Guest AFRO_BOY
I forget that all you guys own nissans. I've got a holden so i don't know about some of this stuff, but either way i'd still use 6" instead of 6x9 if u can save the cash coz you want more sound in the front.
A mate of mine has only got tweeters hooked up to his stock speakers with his high powered subs, and then made his front splits REALLY powerful
In my old WRX, I never used 6x9's in the rear. Because I've always believed that 6x9 are for those who can't fit a sub. Keep in mind that I'm after clarity rather than loudness. 6x9's plus a sub will make the bass sound muffled.
But if your after loudness, fit 6x9's in the rear.
remember when you do your stereo- you dont drive you car from the back seat, or watch a concert with your back turned.
put all your speakers in the front of your car!
buy some shitty 5" coaxails for the back
the only reason people put car audio gear in the boot is for space.
Originally posted by 400HP
what setup did you use dude? and more interestingly whats the setup in the gTR?
Sorry to say but the GTR is strictly for road/track. Therefore the audio is stock as a rock, except for the Kennwood deck. Less weight.
The WRX however, was more interesting. Deck was an Alpine unit with an equaliser and 10 stack CD. Front splits were 6' MB Quartz splits and the rear were 6' Phillips 2 way. The Subs were 2 Kenwood. Amps were 2 Nakamichi. One was a 4 way (for the splits) and a 2 way (bridged for the subs). Pretty hairy stuff as I was after clarity rather than noise.
But then again, that car was total rice. That + bodykit + lowered 18' rims. You get the drift.
Guest gee-wizz
Why did u mix quality gear like MB Quart & Nakamichi with Kenwood & Phillips?????! Oh well i'm sure it would still sound nice :uh-huh:
I'm pretty happy with the gear in my r32. Ive got a pioneer deck, MB Quart 5 1/4" splits up front, Rockford Fosgate punch 6" 2 ways in the back (6X9's are a waste if u plan on running subs) for the rear fill, 2 10" Alpine subs with all the speakers running off V12 amps. i would have preferred to go some 12's (Infinity reference 12's would be joy!) but i had these leftover from my last car.:)
good luck!
Guest gee-wizz
Originally posted by ultim8DTM5
i can defend philips as useless rear fill, as for kenwood, theyre new dB subs are quite the goods...
as for yourself GEE-WIZZ, unless your rockfords were fanatics i dont want to hear a word from you!!!
jk
Sorry mate I didnt mean to offend you! :D Its just an unusual mix between high end and average gear. I'm not doubting that it sounds good! as for not having RF fanatics for my rear fill -I think that would be a bit of a waste (unless u have coin to blow). The 6" punches do an excellent job :uh-huh:
apologies if my original post sounded like i was having a go :P
Those Phillips are to fill in the rear. So why spend so much?
As for the Kenwood subs, at the time, they were the best 12" on the market. Remember that I brought this around 1996 or 7 I think. Trust me, they killed a lot of other stuff on the market at that time.
apologies if my original post sounded like i was having a go :)
hah yeah i was piss-taking too, felt i had to defend silver-arrows on his ol skool install (not as many brands around in 97, thou this was the 'lets build door pods!' phase of car audio, sadly missed...)
:burnout:
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
