i wanted a gtr could have gotton one but i wanted a gts-t first cause i thought it would be a bit more fun in the drifting and skid sense...... ill get a gtr next.........i went for the 32 cause there are way too many 33's here so i wanted something a bit different....
Originally posted by ex-static
Change the Pole and put an r33 s2 on there
Ditto to that! Be interesting to see the split of S1 to S2.
Plus I'd put the R32 & R33 GTS4's in their own categories. Very different beasts! RB20DET turbo vs RB25DE NA.
Originally posted by GTS-4OrCeD
Yeah I would have split the r32 and r33 GTS-4.  The way you have it at the moment puts me in the same catigory as Joe PVA-Glue.  I now feel quite ill, and will no doubt have a sleepless night. :)
Greg. :)
hahahah :lol:
yeah I agree :)
Yeah I would have split the r32 and r33 GTS-4.  The way you have it at the moment puts me in the same catigory as Joe PVA-Glue.  I now feel quite ill, and will no doubt have a sleepless night. :D
Greg. :)
hahhah lol... I didnt even know...
I voted R33 GTS... :lol: soz
anyway :bahaha:
cheers
Joe
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
