Sorry if this is the wrong section...
But is a mini-spool or any other locked diff available for an R33 gtst? anyone using one?
edit: is it possible to weld the standard diff? is this reliable?
cheers.
Edited by bilbo117
https://www.sau.com.au/forums/topic/95009-mini-spool/
my sugestion is to buy a non turbo one and weld it up(too hard to weld a viscous)
this way after you get sick ok the rear driveshaft clunking you can put the stocker back in.
if its a drift or drag only car im sure they are available.(they raced with them )probably from the usa.
https://www.sau.com.au/forums/topic/95009-mini-spool/#findComment-1722064
I don't see why you would bother with a spool or mini spool when welding the diff is basically free and works exactly the same way.
You are much better off getting a mechanical diff centre though, between 500-1500 fitted.
https://www.sau.com.au/forums/topic/95009-mini-spool/#findComment-1722596
I have never heard of a problem, even in seriously abused diffs. Yes the shims can wear over time but they are simple to replace.
But the problem with a locker or spool is they are 100% locked which makes them dangerous in the wet, difficult in slow turns etc etc. These things affect you every day as compared to the chance of wear over time.
https://www.sau.com.au/forums/topic/95009-mini-spool/#findComment-1724368
i use a stocko-welded diff in my r32, been drifting it once a week for 6 months now and it's still going strong.
A welded diff will start to whine before it breaks -- as soon as that starts happening, swap it out, because as some1 else said, it's undrivable when it brakes.
Getting it shimmed up is not worth it, it will act the same as welded for a while until shims wear out and then it will just single spin again. U may as well weld it.
and just to add, I don't know anywhere you can buy mini-spools for skyline diffs, but that would probably be better than welded. Skyline driveshafts and diffs are very strong and last ages if you weld them.
Edited by MerlinTheHapyPig
https://www.sau.com.au/forums/topic/95009-mini-spool/#findComment-1728524
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
    • My purchase experience was no where near as glorious as yours but still a significant moment in my life! Yeah that's a bit of a dilemma as to whether you bring it back or not!  Obviously a massive waste of time and effort to bring it back if you're only going to move there anyway!
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
