  • Replies 149
macers is off showground road, up the castle hill end (think it could be old northen raod end) .. ether way its near the shops end, hard to miss, just look for the big yellow thing :D
oh and yep ill be there at macers too at 8am with moanie
All good.
Have just checked the forecast and it looks like we can expect some good weather tomorrow. Hopefully, we can also expect a good turnout, with around 65 RSVPs.
Don't forget to you'll need to have at least ONE current member of the SAU NSW Club in the car to come along (non-members can join on the day). This goes even if you're not planning to do the observation cruise because the entire event, including the barbie, is covered by CAMS permit
Any club member who can't find a passenger but still wants to come to lunch should meet at Krispy Kreme. We'll still need you to sign the entry form and will provide details of the final destination once the last cars doing the observation cruise have left.
Don't forget to fill your tank before getting to the starting point, the cruise to lunch is over 150klm :D
Don't forget to bring a picnic blanket/ chairs etc to plant yourself on at the end
If anyone gets lost in the morning, or has any questions, you can call me on 0412 530 276.
Otherwise see everyone tomorrow!
Kel
Kel can you take me off the list...
I cant make it.....work committments means less time to study.
Silver PM me your number and depending on what time you leave I MAY be able to cruise with ya to the destination
Can you send me a text if you look like making it to lunch?
We'll need to orgainise an entry form for you, just in case you fall on the barbie/ trip in the car park etc etc etc
Thanks
Kel
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
