how ya going guys, i was just wondering if anyone on here has had to have their car exempt from compliance? and if ya have or know anyone that has do you have any advice? helpful tip/hints to help me get through. cheersguys and thanks for the help!!
https://www.sau.com.au/forums/topic/95045-exempt-from-compliance/
I don't really understand your question?
Almost all cars have to meet ADRs to be registered.
If it is a 15yo or personal import, an engineer can confirm this
If it comes in under SEVS it is up to the complier to confirm it
If it is rally import it does not need to comply.
But this all depends on what the import approval was in the first place?
i had to do the exact same thing, in fact I was actually going to look at the car you bought but the dude never answered so i ended up getting another GTR in Vic.
If you've got any specific questions pm me and i'll be happy to pass on what happened to get my car through.
tom
yeah got no complance plate under the bonnet. apparenty it wasnt fitted(the car came in under the 15yo rule) i have the engineers certificate and import approval. and some peice of paper that i had to sign (buyer and seller thing) when i got the car.
15 year old cars don't get compliance plates... they'll have an australian VIN number stamped onto the chassis or rivetted onto it, which should come up on the system though. If you have an engineers cert and the engineer is recognised by your local road transport authority, then you should have no issues.
We bought an 89 GTR from Sydney. As 89s do not come fitted with the green compliance plate, the car had to undergo a full inspection at Regency, along with us having to show proof of compliance (i.e engineer's certificate) and import approval papers.
Regency provided me with an Application for Exemption from Compliance Plates form which had to be filled out and submitted with the other import papers etc.
Ours was a fresh import and had never registered before, but we were advised that even if it had been previously registered in another state, we would still have been required to undergo a full inspection.
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
