Miscellaneous Items
Item Condition: All in good or excellent condition.
Price and Payment Conditions: Prefer cash, direct deposit & COD can be arranged at buyers expense.
Contact Details: PM me or contactable on 0418123224.
Hey All
Cleaning out the garage and have the items below for sale..
Various R33 Standard n aftermarket parts
NGK IridiumIX Spark Plugs (x6) 2 Suit R33Gts-T (Brand New) ($105)
R33 Front bar (Slight-Damage) (White) ($50)
Aftermarket Viscos R33 Gts-t Lock Diff ($600)
Under Car Support Arms to suit either (S13, R33, R34) ($50)
Audio
Soundstream Mules 12inch x 2 in carperted box (250RMS) ($550)
Pionneer Spilts ($100)
10inch x2 Pioneer Subs 700WATT Brand New In Box ($150each)
Assorted Items
01-02 Orginal Lancer Tail Lights ($100)
s15 standard orginal front bar (Black) ($250)
(1990) MX-5 Orginal Tail Lights PAIR ($100)
R32 TEIN - HR Suspension (Near New Condition) ($1000)
R32 TEIN TYPE FLEX Suspension (Near New Condition) ($1000)
ER34 Blisten Full Suspension ($600)
R32 KYB Buzz Spec (circuit touring) x2 Front Struts ($150)
ST185 GT4 FrontCut ($2000)
R32 (Coupe) Sunroof ($200)
DS060MT Toyota GT4 Head Gasket Set/Kit ($250)
Body Kits
Subaru Impreza 93-01 SYMS Complete Kit ($700)
Subaru Impreza 93-01 Zero Sports Complete Kit ($800)
Mitsubishi Lancer 99 4-Door Evolution 6 Kit ($700)
Nissan s15 Cwest Complete Kit ($900)
Nissan s14 Nismo Complete Kit ($800)
Mazda rx7 series 6-8 Veilside Style Complete Kit ($800)
Wheels
16inch (Setx4) Nissan Standard R33 Wheels w/SNOW TYRES ($250)
17inch (Setx4) FALKEN Racing Spec Tyres (225s) Near New Condition ($150each)
17x7.5inch (Setx4) Degeo Alloys w/ Falken Zeix tyres 235/45/r17 70% Tread, 5stud 2 fit skyline, etc. ($950)
16inch R32 GTR Wheels & Tyres with 80% Tread, 5 stud, s15, skyline, etc.. ($750)
PM me for any further details, hopefully these pictures will help with sale...
Edited by chris2five
https://www.sau.com.au/forums/topic/95055-fs-r33-miscellanous-items/
  • 2 months later...
  • 1 month later...
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
