Hi ppl,
Just hunting round for a decent electronic boost controller and at the same time not spend too much.
I was looking at the Greddy Profec B-Spec II and the Turbosmart E-Boost 2 ones. Bit pricey but hoping to maybe find S/H.
Just want to know from peoples experience which has been good for them etc.
Cheers!
https://www.sau.com.au/forums/topic/95060-which-electronic-boost-controller/
hey Pulp,
I've got an Greddy Profec -A, althou its not the one your looking at, i find it to be top, holds boost perfect and very easy to tune.
so going by that i would say the Profec B would be very similar.
Just had a quick look for Profec B and looks like the range from $300 to $500, if you cant get one for cheaper than $400 you might aswell go something like blitz ID-3
I know it's a bit off, but personally, i'm a Apexi fan. So it's the AVC-R. There's a reason why Apexi has not upgraded the AVC-R since it's launch, cause it just works so well. There is not much of a need to upgrade it. Some pple said that the AVC-R's solenoid is a perfect replacement for a skyline, which i think is just biasedness again, and should be bullshit. LoL.
My .5 cents worth. Again, remember. I'm a apexi fan. LOL
Thanks guys!
EVL, I'll check out the Profec -A, sounds ok.
KeeFy, yeah I like the Apexi gear too, am def getting an SAFCII and wanted an e-boost controller as well, but I think the AVC-R is pretty pricey compared.
I'll see what I find!
Doesn't really matter I spose Dan, is it better to buy through Nengun?
Although been speaking to Lumpy at Hyperdrive and he said cause my trans is Auto, to get the HP I want I'd have to go either PFC or a Greddy E-Manage kit. The SAFC combination wouldn't control or handle timing well etc.
The PFC would cost me more cause it takes more to tune with auto. So the E-manage kit would be a slightly cheaper and better option as it can be piggy backed.
pfc Does not work with auto nissans.
already been down this path.  I ended up getting  the emanage ultimate and profec e 01.
Yeah I'm thinking the same thing hey!
Did you do anything to the trans anyway? like any mods etc, or did it handle it fine?
no mods to gearbox as yet. will be getting shift kit form mv automatics though. PFC just will not work with the shift logic of the skyline gbox. I would have prefered pfc, but atleast you can hook emanage up to laptop and tune it yourself.
yeah i thinking of getting an electronic boost contoler looking for second hand APEXI AVCR i think they seem to be able to do the most rather than just plain two boost setting and thats it. Mines also auto buy yeah its a r32 so different to you guys.
Mad34 let me know when you get the shift kit from MV i was gona get one too and a trans cooler maybe cheaper to get together even if they are different
Hmm I've known a few people with AVCRs and even though they look nice, they've all had dramas. Not holding boost, too tricky to use etc etc. One of them switched to a Greddy Profec B Spec II and said it was awesome. Controlled boost a lot better.
But I do admit the AVCRs look sweet :)
E boost 2 are the best no spiking + you get a boost gauge with it
they are australian and the after sales is exerlent
i have one and was unhappy with it so i e mailed turbosmart and 30seconds no shit i had a phone call asking wat was wrong
they promtly told me how to use it my self now i agust it and my car is running very good
i have set it so good i hav the best power band and wen i get an e management i will play around with it again
james
theres a new blitz i-color or something with the slick colour screen and more logging/display options . the id3 has a mono screen and still has some pretty good monitoring/logging options
the duty cycle/boost curve learning thing can be tough to setup but its great when its working . the blitz can be set to manual if you want to go old school
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
