Howdy ppl....
I thought i'd ask before i go and try pull everything apart:
The button lights on the left hand side of my climate control dont seem to be working. That is the MODE, A/C, "FAN", "Temp Down".
Can these lights be changed? Is it simply a matter of taking off the dash facia and then popping off the Climate Control facia?....If so, what globes/led's will i be needing?
Cheers
EDIT: Sorry its a R33 GTST
Edited by R33_STEALTH
https://www.sau.com.au/forums/topic/95065-button-lights-on-climate-control/
They can be changed - quite easily! If you remove the whole control unit, you'll find little circular plates in the back with a flat head indentation on them.
Twist these 1/4 turn anti-clockwise, and they should pop out. Each one holds a tiny globe (grain of wheat globe, is what Jaycar/DSE will know them as) and you just need to replace these.
Only prob is each globe has a blue rubber cap over them to give that blue/green tinge instead of yellow incandescent light. These get brittle with the heat of the globe over the years and will be impossible to remove intact. You might be able to get a replacement cap (hopefully silicone so they will come off next time) at the same place you get the globe.
I see.....
Except i dont get one lil bit...when you talk about the circular plates in the back....u mean actually inside the unit? So do i need to open the unit up / pull it apart?
I read the thread linked by midnight. Have just replaced the bulbs with the "grain of wheat ones from Dick Smith.
Cost was $2.50 for a pair.
1. Take the control unit out
2. Undo the two bulbs with a quarter turn
3. Unwrap the thin wire holding the bulb to the holder that makes the actual "contact"
4. Carefully push a toothpick under the blue condom and roll it around the bulb to separate the rubber from the bulb.
5. Reverse order for new bulbs.
Simple. (Although on the one pictured I left a tiny bit of the blue rubber on the old bulb. I managed to get it off completely intact with the other one.)
Look closely and you can see the wire wrapped around the base of the holder. (This is the replacement globe in place)
Enjoy!
El Bee
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
