Hi,
I've had my r32 for about 2 weeks now, still getting used to all the random sounds the car makes... There is one which doesn't sound too good, sometimes when i change gears or reverse theres a clunk sound coming from the rear of the car... could it be the diff?
All the gears seem fine, although reverse is a little sketchy at times. And the clutch seems ok too. It doesn't seem to effect the drivability of the car, but i'm ultra paranoid about blowing a gearbox or clutch so soon after buying the car. Anyone know what it could be?
thanks
Kat
https://www.sau.com.au/forums/topic/95069-strange-noise-r32-gts-t/
it happens when i have been driving for a while, usually when i change gears, or give it a bit..
the car is getting tuned and dyno'd today so ill ask the guys at racepace what they think.. im so fcukin cluless atm, need a bit of light shed on a couple things.. then maybe i can stop stressing.
If you can jack the car up onto just the front wheels, give the rear wheels a bit of a spin and if theres slack or it clunks then Id say its your diff/tailshaft, otherwise probably bushes as suggested, they are very cheap to replace. Diff can vary.
Unlikely to be the gearbox, unless its crunching etc.
yeah mine also makes the same noises you described.i mite look into changing the oil,but its unlikely to be that.(when its complied in australia they are required by law to change EVERY FLUID in the car) diff,gearbox,clutch,engine ,brakes,etc etc...weather they all do is another story.
i just got a new clutch (brass button) and as its much harder to change gears..i can feel the torque straining it, especially in reverse.
As for reverse being sketchy when using reverse put it in 4th or 1st first then straight into reverse.
Nah,i recon thats just dodgy...who wants to muck around with two or three extra gears when it should just slide straight into the one you select ?. :D
if your havin trouble now,it will just get worse so it REALLY needs to be looked at. :)
Nah,i recon thats just dodgy...who wants to muck around with two or three extra gears when it should just slide straight into the one you select ?. :P
That's not true - alot of nissan sr20 and rb20 matched gearboxes do that. I understand what you're saying and I agree - but it's well known and I think many people do it and their gearboxes aren't going to blow up :)
That's not true - alot of nissan sr20 and rb20 matched gearboxes do that. I understand what you're saying and I agree - but it's well known and I think many people do it and their gearboxes aren't going to blow up :P
This is true but it will also help to determine whether you have a gearbox or diff problem.
If by changing into 1st then back into rev stops it from doing it's thing then it is likely you have a gearbox problem.....nothing major as pretty much all of them are doing it by now.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
    • How do they compare in size? I have the Yaris coil packs in mine and they work fine. But they are either bigger or sit differently so the engine cover doesn't fit anymore. Not the end of the world but not great either. Do the R35 ones sit flush?
