saw SXY-25T
ae86
 Share
  • Replies 93
Originally posted by darK
and whats that?
Cut Rice with yummy Marinated Pork Chop with Dried shredded Pork skin marinated with a yummy delicous quiche topped up with Nuoc Mam.
I promise you its easy even for a Anglo Taste Bud :D
Its is yummy!!!
Tell your viet friends
Originally posted by UR2EZ
mmmmmmm samosa.... yummy
you understand the taste of the samosa..
mmmmmmmmmmmmmmmmm
deep fried by 'moia'
Originally posted by DR GTR
I love Curry.
Inasnt my buddy is a curry too!
get him to eat some Viet Food.
will do.. lol
Originally posted by GOLD^MemBeR
hahaha.....dont underestimate his 4wd sr20det....
its got sum guts
hahahah you mean FWD then it hooks up the rwd.
It might as well be a FWD pulsar hahaha.
The car looks like a warped Jelly Bean.
And what about mynas BF? hahaha SXY-33T ?
Pfft how original hahaha
 Share
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
