Celica Ta22 with SR20DET engine and gearbox conversion complete.
Engine and gearbox in perfect order, comes with custom extractor manifold,
inlet manifold, injectors, coilspacks etc.
Autronic smc allready wired to SR20
Fuel system /surgetank, pumps etc
Custom aluminiun fuel tank fitted
One piece tailshaft brand new
Heavy duty clutch
Front mount intercooler fitted
Recently fully repainted with after spoiler kit
Full custom interior
4x autometer gauges tacho etc
"17" Simmons Wheels gold
Sun Roof fitted
Custom Differential VL commadore shortened to suit with brand new LSD center and 4.11 gear ratio and Disk brake
Brakes, aftermarket front and rear
Upgrade suspension
"3" inch exhaust complete system
plenty more extras
It is registered but not with the SR20DET.
Needs minor work to run.
Price $7500 complete
0425 799 984
https://www.sau.com.au/forums/topic/95104-celica-ta22sr20det/
    • Wanted to clean the film behind the triple gauge so the lights show through better.  Progress so far….
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
