Hey Pulp don't worry about your reaction time unless you want to beat someone, if you are just after your personal best time, the reaction time isnt counted into your 1/4 time so you can launch whenever you want... but don't keep people waiting too long :huh:
  • Replies 199
Nice to meet everyone last night.
I ran a first time out of 13.1 @ 105mph on 12psi so I was happy not to break anything and learn alot (ie learn my clutch slipping point!)
Nice to meet everyone and put faces to names!
See you round.
PS: Big thanks to TOPAZ for the loan of the helmet...
no probs man, didn't think I was gunna get it back there for a while... :huh:
You got a 13.1 at 105mph and I got a 13.5 at 105mph....did you have a good start?, coz I know I didn't get 1 decent start out of the 4 I had...
good to meet a few of the guys last night(i was in the gun metal grey auto r33), i really enjoyed myself. Ended up with the final run of the night being my best of 14.359, 2.359 60' at 160.21 km/h, not to bad for a auto. very happy with that (intercooler did its job) since couldnt crack 14.7 without it.
Fiona - congrats on your PB :D
Thanks :D It made my night haha (for the record, 13.2 @ 108 mph). I know I shouldn't expect too much from it when it's not running properly, but my heart is set on a 12 haha!!! Once it's tuned it should be similar to rhianne & jeremy's.
Was nice to meet everyone last night, I had loads of fun :) Thanks for organising it!
I was there specatating last night looked like a good turnout...that Black R34 GTR was Gorgeous!
and plenty of 32 GTR's as well B)
Although I was surprized at there MPH,s I thought they'd be a bit quicker over the line.....? :D
I thought mine was fairly stock but seems to run 10kmh faster over the line..!..?
Could the 32 GTR drivers post your Mods, HP, 60ft times etc
Cheers
Lindsay
Lindsay from Atwell? I remember you from R31SkylineClub, I still want a ride in your car! :blink:
That'd be me :)
Welcome to pop over anytime for a spin, although Passenger seatbelt needs fixing as it wont retract so maybe not a good idea atm :O:)
Lindsay,
My car is in desperate need of a tune so I don't think my specs are very helpful.
310ps @ all 4 wheels on 1.0 bar boost with boost controller, air filters, exhaust, HKS twin plate clutch w/ lightened flywheel, mechanical lsd in rear, GReddy pipe kit and mines rom.
Best time is a 13.2 @ 108mph w/ 2.0 sec 60ft (lousy I know). Car is getting far too much fuel though. Timing was put back to stock after engine rebuild so I wouldn't damage anything, and fuel mixtures set a bit rich.
Now ready for a proper tune and a bit more timing. I'm hoping for a mid 12 after that.
Edited by randominsanity73
no probs man, didn't think I was gunna get it back there for a while...  :)
you werent! I couldnt find you....:P
my starts were bad I think....
2.0 60'
2.15 60'
Next time a 12 should be within reach.....:)
had a blast cheers for organising would def do again and cheers to all for makin me feel so welcome
times wernt great but eh i dont really mind only thing that pd me was my damn 2 ta 3 shift ill get it one of these days
gota stop linin up gainst gtrs tho make me look even slower
For the R32 GTR's I was the slowest :)
Jeremy/Rhianne - 12.6/12.9
CJ23WA - 13.1 (Sorry, forgot your name dood)
Fiona - 13.2
Me - 13.5 :(
I know I can go faster and get a lower 60' time, but my clutch was wiffy. I'd also like to know how much power CJ and Rhianne's GTR has...both gotta be over 300hp I rekon ;)
    • They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
    • I was under the impression the reason why OEMs are going with solutions like relatively thin "right-sized" cylinder walls with technologies like PTWA and open deck is because they care a lot about whatever marginal knock margin benefits they get from that vs the structural rigidity benefits of a closed deck block and thicker cylinder walls. I also see some weird stuff like plastic inserts in the water jacket around the cylinders to try and equalize cylinder wall temperatures. re: the PRP blocks and heads at the end of the day it's hard to know what is and isn't going to work there, just have to see what the initial buyers say about it.
    • Which is why I didn't mention that hardness testing, and specifically mentioned the bore and deck thickness testing. Yeah, not really. The bore temperature will be a lot more even around the top half inch or so, where the material distribution is dominated by the deck, and which is the only place where the bore surface temperature heating any gas in the cylinder is likely to have any effect on detonation. Think about it. Another inch or so down the bore, you might have a hotter spot. The gas there might get a bit hotter, then the piston rises squeezes that gas away from there at high speed and mixes it with other gas from nearby. Instant dilution of the problem. I'd be surprised if it was an issue at any time other than in racing engines or OEM dev engines being run at the ragged edge of tuning. Say what now?
    • https://dsportmag.com/the-tech/education/engine-tech-material-hardness-testing/ The PRP testing on block hardness I'm not sure how much it actually can be trusted. The thinner cylinder walls on RBs is a bit of a problem vs 2JZ but it really depends on the design goal. Siamesed cylinder bores like a 2JZ cause uneven cylinder wall temps too, which means a bit of distortion induced by that + the hotspot can affect knock margin. Something that actually gives me a bit of pause with the PRP block, whether super thick cylinder walls are going to keep it from being drop-in compatible on an otherwise OEM rebuild.
    • Yeah very valid point. I am waiting for one of the other tuners to come back from vacation so he can help me a bit when the cat is installed again. In the meantime I am going to finish up my polishing and ceramic coating that I have started myself.    N45 Dr Beasley product is highly recommended for a paint primer / polisher. Using this EXO Gtechniq also for the ceramic but next time might use the light serum before hand also. Looks great.
