I want to get the seat rails moved back (bolted further back in the car) or leave them where they are, but extend the rails (weld extra lengths on) so the seat has more travel.
Does anyone know which option would be easier or more feasible? Who can perform this work? I imagine I will need to get it engineered?
This will be for the drivers seat. I've noticed in the R33 the front part of the rails is bolted to a raised section of floor, thus if you moved it back you would have to straighten this piece out. Are there any other things which come to mind?
Has anyone else done this to an R33?
Thanks in advance.
https://www.sau.com.au/forums/topic/95123-seat-rail-modification/
Nope I haven't ever tried this, but I can't see how you would extend the rails, it would have to be moving the rails backwards. Basically you need a good workshop to help you out I'm sure they can extend the mounts to give you an extra bit of room.
Maybe new rails could be fabricated that are longer. I don't know that you could do that at home though.
I'm also 6'5" (nearly 6'6") and I have no real problems with my R34. I need to lay the seat back a bit when wearing a helmet though.
Maybe you could get a race style seat (I think Ducan can get them :)) as this would sit you lower giving you more headroom.
Do those seats need new rails?
Headroom isn't really a problem for me, it's more legroom as most of my height is in my legs.
If my left foot is on the clutch fully depressed then my knee fits comfortably under the steering wheel, otherwise, with my foot just resting on the clutch, my knee does not fit under the wheel and has to sit to the side of the wheel. Obviously, the same applies to the right hand side.
Although a spacer or dished steering wheel could possibly free up some room for my knees, my arms are already close enough to the wheel, so I'd like to actually make the seat further away.
What are the mounts that the seat is bolted to? Are they special reinforced areas of the chassis such that you couldn't simply drill new holes to mount the seat further back?
Thanks for your help guys.
You can't just move the mounting points further backwards, you need to fabricate a mounting plate the rails will go to the plate and the plate will bolt to the seat, you can get a couple of inches here easilly without too much trouble but I wouldn't go past 15cm. You will need this engineered as well.
Yes the mounting points are specially reinforced and new mounting points would need to be as well. But its not that easy because the floow is nothing like flat so the rails need to take that into account.
  • 3 weeks later...
  • 5 years later...
I'd be careful and ensure that you get any seat mod engineered, I can see popo having a field day on this if you just do a back yard job. Esp. if you also do the passenger seat and are then involved in an accident - or sell the car and it is involved in an accident.
  • 1 year later...
Mine have been moved back on bride rails but on r34 sunroof still no headroom at 6'2" but large build not skinny butt
I'm back about as far as legal you cant be passed a certain point on the B pillar or seatbelts wont work now i need monkey arms cause I have to lay the seats back still ( new seats as well)
Wilshire motor trimmers does seat mods and engineers them in adelaide but wanted to do serious mods to the floor pan mounts etc , 1400 to do 1 drivers seat , just regular mount passenger side and the customer service was lame so didnt use them , still not happy with seating location , going to look at dropping the seat inside the bride rails to gain 40mm or so
Sunroof cars loose 30mm headroom per sales manual , Damn jdm cars with no leg room lol
Funny thing is when I was in japan I saw some tall asians , like 6'5" only thin as a rail , wonder if they cuss the local cars too ?
I am 6 foot and there is around 10 inches clearance from the roof lining to my head, plenty of room, even to slide a helmet on in the car.
Sounds like you need to sell the 34 and upgrade to a V35 or M35 Stagea. :)
I'm 6'8" and actually don't find my 33 GTR too bad (relative to my Datsun 1200 Ute anyway!).
In Melbourne there is a business in Coburg (Franks Engineering) that perform seat modifications and engineers them.
I seem to remember them being pretty good price-wise.
Hmmmm NO
R35 2013 black edition modded to hell YES
My old dodge 4x4 v10 extended cab fit ok haha piece of crap
To fix the problem - ADR rules in bin and do it even better like a rollcage with backing plates thru the floor and add crossbracing for side impacts lol
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
