Shell has released a new fuel Optimax Exteme.
It is at least 100RON blended with 5% ethanol.
The shell near my house stocks this fuel and I filled up a tank thinking it was regular optimax.
Anyhow, my car stalled, and jerked continuously. It would not start at times, and just ran like crap!!!
I highly recomend you do NOT use this fuel in your skyline, or any high performance nissan!
I took this from the subaru website, and I guess this also applies to forced induction Nissans also...
All model year Liberty B4 and Impreza WRX STi MY99-00 models may experience starting and or drivability concerns if ethanol blended fuel of any level is used and therefore we do not recommend its use.
For a list of Shell servo's that stock this fuel, visit the shell australia website, and follow the optimax extreme links....
Z
https://www.sau.com.au/forums/topic/95126-optimax-extreme-100ron-5-ethanol/
  • Replies 168
Ive used 10% Ethanol blended fuel rated at 98ron, and it was SMOOTH-AS (it was say half a tank of E98 and half tank of BP 98) in my RB25det.
But I wouldnt use E-blended fuel all that much, only in half tank lots every now and then.
Brendan
Apparently if you want top performance on regular pump fuel you'll actually find these ethanol blended fuels provide the best performance as long as you get a TOTAL retune. Else I'd probably steer clear as if you have a highly tuned car it will lean out alot more using an e10 or e5 fuel.
well when i was at 1/4 of a tank, i filled up with regular 98RON optimax, and within 1km of driving, all my problems were solved.
Nissan recomends you dont use it, I have provided my experience with this fuel, Just trying to warn others...
Edited by Zahos
thats the beauty of a remapped ecu just pull battery lead off and leave, come back all is forgoten, i wll only try this with half tanks at first, utilmate 98 plus the 100 stuff.
Edited by race_snooze
hu? Its not a remapped ecu then. :)
I used a full tank of E10 fuel(10% ethanol) and the car ran great,but my current tune is a little rich.Can someone PLEASE post up Shell servos that have 100 octane fuel in Melbourne.I'm going to tune both my Nissans for this fuel.
I'll be following this thread to hear about peoples experiences before I fill up with the stuff. I've got a stock ECU with a couple of mods, so it runs rich as anyway....
http://www-static.shell.com/static/au-en/d...ite_extreme.pdf
It states it in there.
Extensive tests were done, some of which were displayed in a recent issue of Zoom of HPI (can't remember which). Basically, it needed some serious retuning; heavy increase in fuel, as it is less dense, and a huge advance of the timing, with a 16 rwkw increase over normal 98 ron fuel.
if you goto fcai.com.au it says there that nissan dont recomend using any ethonol fuel in any car made before 2004.
hence y i wont use it.
SSS_Hoon
Exactly.
And Iexperienced the problems mentioned:
- difficulty starting
- poor drivability
Edited by Zahos
ummm.... 100ron.... aint japanesse fuel an even higher rating... why would our cars have a problem with it........ obviously its just tuning... reset the ecu should be fine... it will return to factory specs... as in japanesse factory specs where the fuel is a higher octane rating...
as for the ethonol... the media gave it the name its got...... id rather see the FACTs on this fuel.. strait from the product producer..... i dont think it would do much damage at all.... and seriously guys.... most of you would rebuild you engine before the effects this fuel supposably has are noticed....
of course with progameable ecus you would retune the car when using a higher octane fuel... especially if you want to take advantage of the higer octane.... your stupid to think a totally differant fuel wouldnt cause problems.
b/c of the ethanol
Is this comment based on more research, or again is your arse doing all the talking?
How can you determine how often people will re-build their engines?? and secondly, by making that comment you basically admit that you think ethanol WILL cause damage.
Edited by Zahos
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
