Shell has released a new fuel Optimax Exteme.
It is at least 100RON blended with 5% ethanol.
The shell near my house stocks this fuel and I filled up a tank thinking it was regular optimax.
Anyhow, my car stalled, and jerked continuously. It would not start at times, and just ran like crap!!!
I highly recomend you do NOT use this fuel in your skyline, or any high performance nissan!
I took this from the subaru website, and I guess this also applies to forced induction Nissans also...
All model year Liberty B4 and Impreza WRX STi MY99-00 models may experience starting and or drivability concerns if ethanol blended fuel of any level is used and therefore we do not recommend its use.
For a list of Shell servo's that stock this fuel, visit the shell australia website, and follow the optimax extreme links....
Z
https://www.sau.com.au/forums/topic/95126-optimax-extreme-100ron-5-ethanol/
  • Replies 168
Ive used 10% Ethanol blended fuel rated at 98ron, and it was SMOOTH-AS (it was say half a tank of E98 and half tank of BP 98) in my RB25det.
But I wouldnt use E-blended fuel all that much, only in half tank lots every now and then.
Brendan
Apparently if you want top performance on regular pump fuel you'll actually find these ethanol blended fuels provide the best performance as long as you get a TOTAL retune. Else I'd probably steer clear as if you have a highly tuned car it will lean out alot more using an e10 or e5 fuel.
well when i was at 1/4 of a tank, i filled up with regular 98RON optimax, and within 1km of driving, all my problems were solved.
Nissan recomends you dont use it, I have provided my experience with this fuel, Just trying to warn others...
Edited by Zahos
thats the beauty of a remapped ecu just pull battery lead off and leave, come back all is forgoten, i wll only try this with half tanks at first, utilmate 98 plus the 100 stuff.
Edited by race_snooze
hu? Its not a remapped ecu then. :)
I used a full tank of E10 fuel(10% ethanol) and the car ran great,but my current tune is a little rich.Can someone PLEASE post up Shell servos that have 100 octane fuel in Melbourne.I'm going to tune both my Nissans for this fuel.
I'll be following this thread to hear about peoples experiences before I fill up with the stuff. I've got a stock ECU with a couple of mods, so it runs rich as anyway....
http://www-static.shell.com/static/au-en/d...ite_extreme.pdf
It states it in there.
Extensive tests were done, some of which were displayed in a recent issue of Zoom of HPI (can't remember which). Basically, it needed some serious retuning; heavy increase in fuel, as it is less dense, and a huge advance of the timing, with a 16 rwkw increase over normal 98 ron fuel.
if you goto fcai.com.au it says there that nissan dont recomend using any ethonol fuel in any car made before 2004.
hence y i wont use it.
SSS_Hoon
Exactly.
And Iexperienced the problems mentioned:
- difficulty starting
- poor drivability
Edited by Zahos
ummm.... 100ron.... aint japanesse fuel an even higher rating... why would our cars have a problem with it........ obviously its just tuning... reset the ecu should be fine... it will return to factory specs... as in japanesse factory specs where the fuel is a higher octane rating...
as for the ethonol... the media gave it the name its got...... id rather see the FACTs on this fuel.. strait from the product producer..... i dont think it would do much damage at all.... and seriously guys.... most of you would rebuild you engine before the effects this fuel supposably has are noticed....
of course with progameable ecus you would retune the car when using a higher octane fuel... especially if you want to take advantage of the higer octane.... your stupid to think a totally differant fuel wouldnt cause problems.
b/c of the ethanol
Is this comment based on more research, or again is your arse doing all the talking?
How can you determine how often people will re-build their engines?? and secondly, by making that comment you basically admit that you think ethanol WILL cause damage.
Edited by Zahos
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
