GCG $1100 i think.
price you pay vs what you get... excellent.
They were crap a while ago, with cracking and stuff, but lately they are are top quality. All reinforced and stuff.
Ive seen one on a car here for 12 months now, no issues with cracking etc
GCG  $1100 i think.
The better quality manifolds are made in TAIWAN, the shitter ones are made in CHINA that are prone to cracking.
Our manifolds are made in TAIWAN, and we have not had one come back in terms of cracking and warpage
Thanks
Tarek
RACESPEC
Ditto, can't see why country of manufacture matters at all.
If I was in the market for a manifold, then I'd really be budgeting about the money that the GCG one is going for. Sure if I can get one for cheaper, thats good quality and I'm happy with then it's a win, but I wouldn't buying something that a POS just because I want to save $500. An extra $500 isn't big money in the scheme of things.
Guys
I have experienced this first hand when I was over the, the raw material in both countries is very different, techniques of manufacture are very very different
I'm not promoting not only my products but others, i sold the cheaper chinese stuff when i first started, and the comebacks i had was ridiculous, just a skip into TAIWAN and there level of products is much much better and many people will vouch for that.
Browny,
Where do you think the GCG ones come from? and the Answer is not Australia.
Do the tests yourselves as we have with TUNEAGENT and you will notice the product differences straight away.
Most Chinese Manufacturers can not guarantee the grade and stainless thickness, once again, not hearsay, first hand experience.
Thanks
Tarek
RACESPEC
it matters when you pay your workers 40c a day and only spend 6$ on materials for each manifold
Are you trying to turn this into an ethical debate? Does this mean you always buy Australian made products?
Racespec,
What I'm advocating is that people don't buy on price alone, or country alone. IMO quality is more important than either (to a point), as is knowing that someone genuine is going to be there if you have issues (which happens with even the "best" products).
If you think I'm not championing GCG's product, i'm not, I think I know where they come from, but that's really only a guess. I really don't care where they come from if it's a good product. What I'm suggesting is that people look at the options available and don't get too carried away with country of origin or saving a couple of hundred bucks, which really is SFA in the scheme of things.
Personally I would look at the Aussie made products. There's one that sells for similar to GCG's that I think looks the goods.
Edited by browny
so are you trying to say that a GCG product is not of "as good" quality as the ones you get?
oh please. for manifolds there is no problem.
Some products come out fine, some dont.
Ext gates/turbos etc are shocking. Just gotta have a look around and see peoples expiriances
No not at all
What I am saying is that the GCG Manifolds are top notch units, as compared to the much cheaper units
GCG
RACESPEC
Bresciani
and others
Sell the same manifolds, not the cheaper quality units made elsewhere
Thanks
Tarek
RACESPEC
From what i hear the new ones are good but the older ones were cracking. I purchased one and we had to spend 10 hours cleaning the dags of weld from the inside so it does not destroy my GT3540. Also had to get all 3 faces machined and we welded a bracket to brace the wastegate pipe to one of the runners.
Have not installed it yet
I bought one from ssautocrome.
Plenty of support brackets and its seemed to have good quality welds etc.
No crap inside of the unit and I no trouble intalling it.
Has anyone else got one of these?
Cost me a little under 500 delivered with a split dup aswell.
Does anyone know much about this company at all.
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
