Rb25 High Mt Manifold?
BOZ22N
 Share
I bought one from ssautocrome.
Plenty of support brackets and its seemed to have good quality welds etc.
No crap inside of the unit and I no trouble intalling it.
Has anyone else got one of these?
Cost me a little under 500 delivered with a split dup aswell.
Does anyone know much about this company at all.
my two cents.
they are all shit. thin wall 304 brittle shit. (in my opinion) i have witnessed many combos.
but they are "racing" items wich are ment to be replaced each season.
no intension to ofend anyone. :)
i had my ebay/xforce one ceramic coated in and out to keep the heat out of it.
all those gcg/ebay ect have runners way to big.
the jap ones are the same. for some reason they all use very big runners for max hp. they seem to forget that most of us only want 5-600hp.
on a 26 1 1/4" to 1 1/2" internal daiametre runners is perfect.
on a 20-25 1 1/4" would be perfect.
you have to rembember that the manifold isnt the restriction but the exhaust housing.
i only bought one because i couldnt be botherd to make another custom one.
i still have the scars on my hands.
but for 300 bucks you cant go wrong.
ps. whats with the chineese t4 pattern that is half way between t3 and t4? the ports line up but the bolt spacing is WAY off.
Edited by T04GTR
i got one form ebay a while ago mive turned out very good it was from the states but like the other fella said get it hpc coated in a out mine has bracketson ot and has been die grinded out was very happy with the result for the price but that could just be a one of
Well I noticed a crack on mine just 2 days ago.
Its right at the top of th manifold so I'm lucky it doesn't need to come off the car.(Very minor hiarline crack)
Engineering workshop said it will be a peice of cake to fix using a tig.
When I get a new turbo some time next year I think I'll take the advice from T04GTR and get it ceramic coated in and out wile the turbo is off.
 Share
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stop on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, you need to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
