Just sold my zed .. 90TT, ive owned a 180sx a sylvia and now a stagea and nothin compared in performance to the zed. Im no mechanic so i wont go into all that side of it can only tell you from my own personal experierience.
Performance... Woohoo!!! when the zeds on boost there is nothin like i was runnin stock turbos so wasnt a full throw back in ya seat like the lighter 180 n sylvia but the amount of torque was amasing you jus watch the tacho rip all the way around, i found by about 5700rpm its time to select a new gear and whoosh ur off again ... very easy to embarass almost anything on the road from a rolling start..(from the lights too but takes a lot of practice with a heavy duty clutch hell of a lot of traction loss with the small turbos coming on boost early heaps of torque and a heavier car).
Handling...For a heavier car i had no problem with the handling even comparing to the 180 although heavier i was able to give it a lot more on corners due to the hicas pulling it back in line (im no drifter- to those that are you would prob disagree with this) Braking was a different issue .. at high speed when i first got it the whole car vibrated so bad and i could hardly hold the wheel .. i took it in to get sorted and apparently thats a common fault with zeds (just some bushes) so i had em replaced wheel allignment disks checked etc and although a hell of a lot safer a speed it was still there so had to always back of the power very early and ease the brake gently.
Mechanically .. well i cant complain bout the engine it was strong as an ox, all i gonna say here is before you buy get a full inspection compression test etc from someone that really knows these cars cos i spent over $2500 just on maintenance. Nothing went wrong but damn mechanics hate them (cos no room) and they charge like a wounded bull to work on em so make sure you get a good one.
Plus's ... Mods hahaha had quite a bit done to mine n got pulled over a few times for an inspection ... gotta love the zed for this ... they never found anything guess its just to hard to figure it out plus with the BOV's and the pod filter hidden in the front. Respond very well to mods so you dont need to do a whole heap. Targa top, electric everything, poss leather (mine did loved it)
Negz.. Mods can be very expensive cos a lot of what you do u need to double up on ie BOV = BOV's, etc etc u get the point, an dthe one and only reason i sold mine was heaps of room in the front but mine was a 2 seater so thats all ya get bud ... heaps of fun for you n one more.
On a closing note dun be scared of the engine like i said earlier im no mechanic but after a lil while i figured most of it out and at one point was able to find where a huge coolant leak was coming from from a tiny outlet pipe from the engine, had to remove the fan water pump etc to fix it but wasnt that big a deal and basic servicing is so easy on them but mechanics wont tell you that.
hope this was of some help to ya
merry xmas
Lee
  • Replies 75
Posted Images
  • 3 months later...
  • 1 month later...
  • 6 months later...
sorry to bring up and old topic how would a 300zx running 14psi with exhaust compare to my gtr , thats only running 15psi exhaust n pods
i'll be hitting the track when i get time to race him, so he finks he will beat me but i kept laughing
is it possible for him to beat me?
  • 8 months later...
  • 3 months later...
Brother had one of these. Had the twin turbo, sunroof, yellow paint job etc, awesome looking car.
Some guy ended up hitting him and the car was a right off. :ph34r:
As said above, he didnt care much for repairs. Usually the engine was pulled out to fix one thing. He was also looking at better cooling before the crash.
These days he drives an MR2 and doesnt look back. :nyaanyaa:
If I was you, I would find something else. Unless you have the money to blow on a car's upkeep.
  • 4 weeks later...
  • 1 month later...
Great cars if you look after them! With 300rwhp mine did a 13.1 @ 175km/h with heaps of wheelspin. Speed indicates it should be a much quicker time it's just hard to get the power down. I only sold mine for a change, always wanted a GTR so thought why not.
Couple of cooling issues but it's just maintenance, ie hoses.
Edited by Vija
In my opinion the 300zx is the underdog of the performance import scene.Not many people have them or modify them...which makes them kind of special...Its probably not a practical car for a family guy but as a speed machine they have got awesome potential.For the guys who have made the effort the rewards have been reaped...But looking under the bonnet...Uhhh!! How is a person supposed to work on this thing ?...First mod would be a heavily vented carbon bonnet to let all that heat out and protect electrics...Definately a car for those who arent intimidated by a challenge
  • 1 year later...
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
