take out the spare wheel, rip out the plastic covering, fibreglass 1 sub in each corner of boot, make up a amp rack in the middle, done :D.
I have designs for a 12" side install sealed sub box too.
it can b done if u know what your doin, if any of u guys went 2 autosalon final battle 04 there was a silver r33 with full jl audio install 2x 12'' subs in the corners and 2 amps down the centre all fibreglassed and sprayed in r34 blue. this r33 is my own car and ill try get some pics up 4 u guys
why 1 sub per amp?
2 subs per amp better... lower impedance more crunk foe ya system...
use 2 x 2ohm subs (Assuming they are Dual Voice Coils), run your monoblock at 1ohm.. a good 1kw RMS of power... considering the monoblock does 1 ohm stable...
thats more power than 2 subs running off 2 amps
Please do
it has a normal size one, like u would find in the engine bay of an commodore for example, also with rca'z what length is reccomended, i was thinking something about 12ft/4m is this right???
im running 4 gauge wiring into a distro block then thats going to each amp 1 monoblock and 1 4ch
system is 2 audiobahn 12z, kenwood 9152d monoblock, clarion 4ch, alpine type s splits for front and rear, and a pioneer audiovisual headunit
thanks
You can fit 'em in, but I would recomend to dump em for some 6.5 or whatever the factory size is as 6x9's are a good comprimise for getting bass without wanting a sub. You have 2 subs so I wouldn't worry about trying to fit 6x9's. If you do however you may need to bend/cut the parcel tray, which I definatley wouldn't recomend.
I'd runn 4g for each amp to a distro block, then 2 or 1g to the battery. Looks like you'll be getting some juice going into your system. Don't forget to fuse it correctly as close to the battery as possible.
ok, yeah ill prob go get a length of it and do that, as my amps are gonna be sitting on the sides of the boot
after spending a few hours working out measurements and all that stuff for my sub boxes, ive marked out everything in my boot, im gonna be making my sub boxes up next week as im going for my ps on monday so i wanna practice as much as possible
ill post pics up once the boot is carpeted
thanks
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
