Hey People,
I have read up on the various o2 threads.
I am trying to find out what readings your Power fc gives for the 02 sensor at idle and cruise conditions is it the same as the R33 gts 0-1V?
This can be found in the etc mode under sw check
Thanks
also for a gtr with mild mods
full exhaust
cam gears
PFC
what sort of L/100kms are you getting
Highway and city
I get 300city and 350 Highway on a full tank (taking it easy)
Thanks alot
https://www.sau.com.au/forums/topic/95195-r32-gtr-and-pfc/
It should oscillate between about 0.1-0.9 volts holding it at 2000 rpm and in a steady state cruise situation. Should be the same for amost any votage based 0-1 volt O2 sensor. Thing to check is the bias to chassis ground and also ecu ground.
It should also be checked with a wide band o2 sensor to show that the 02 sensor is not slow to react. Often harder to tell then just a faulty sensor.
https://www.sau.com.au/forums/topic/95195-r32-gtr-and-pfc/#findComment-1722366
Thanks for the help, the bias to chasis ground where is the best place to check this?
Also I think the R32GTR and R33 GTR have different 02 sensors R32 is the smaller style nut R33 is Large style but the Power fc is for both r32 and r33
Does the 32 o2 sensor even work with power FC?
This is the same as S13 early models (red top) have small style late models have large style nut eg (black top)
https://www.sau.com.au/forums/topic/95195-r32-gtr-and-pfc/#findComment-1722769
They both use a 0-1volt range as far as I'm aware so it should have an issue PFC. Chassis ground - as in anyware you can get a good contact to ground ie in a bolt hole. All your doing is checking that there is no voltage between grounds for the o2 sensors and chassis or ecu.
https://www.sau.com.au/forums/topic/95195-r32-gtr-and-pfc/#findComment-1723151
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
