Hey People,
I have read up on the various o2 threads.
I am trying to find out what readings your Power fc gives for the 02 sensor at idle and cruise conditions is it the same as the R33 gts 0-1V?
This can be found in the etc mode under sw check
Thanks
also for a gtr with mild mods
full exhaust
cam gears
PFC
what sort of L/100kms are you getting
Highway and city
I get 300city and 350 Highway on a full tank (taking it easy)
Thanks alot
https://www.sau.com.au/forums/topic/95195-r32-gtr-and-pfc/
It should oscillate between about 0.1-0.9 volts holding it at 2000 rpm and in a steady state cruise situation. Should be the same for amost any votage based 0-1 volt O2 sensor. Thing to check is the bias to chassis ground and also ecu ground.
It should also be checked with a wide band o2 sensor to show that the 02 sensor is not slow to react. Often harder to tell then just a faulty sensor.
https://www.sau.com.au/forums/topic/95195-r32-gtr-and-pfc/#findComment-1722366
Thanks for the help, the bias to chasis ground where is the best place to check this?
Also I think the R32GTR and R33 GTR have different 02 sensors R32 is the smaller style nut R33 is Large style but the Power fc is for both r32 and r33
Does the 32 o2 sensor even work with power FC?
This is the same as S13 early models (red top) have small style late models have large style nut eg (black top)
https://www.sau.com.au/forums/topic/95195-r32-gtr-and-pfc/#findComment-1722769
They both use a 0-1volt range as far as I'm aware so it should have an issue PFC. Chassis ground - as in anyware you can get a good contact to ground ie in a bolt hole. All your doing is checking that there is no voltage between grounds for the o2 sensors and chassis or ecu.
https://www.sau.com.au/forums/topic/95195-r32-gtr-and-pfc/#findComment-1723151
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
    • Jousting sticks! Tell 'im he's dreamin!
    • GTR owners are wankers - 2025
