lol dude I think you should read the manual that came with your camera.
thanks for the constructive criticism
seeing as you've already proved how worthy you are to make such a comment, we wont need to hear any more from you
thanks.
https://www.sau.com.au/forums/topic/95241-my-artwork/#findComment-1730790
good compositions, nice effort.
As i'm a bit of a photoshop junkie, I could recomend it to clean up inperfections such as over exposure etc... I usually only ever get a handfull of good pictures out of the hundreds i take, but I usually help along some of my not so bad ones with abit of editing.
Keep em coming, i wanna see more.
https://www.sau.com.au/forums/topic/95241-my-artwork/#findComment-1734337
Thanks for the comments guys :D well the nice ones anyways. i honestly have no idea with camera's i just take it out and take photos, lol. sometimes they are ok, others not. i have so many on my computer, lol
Kat, the gwen stefani one has been lightened in photoshop because it scanned so dark.. just thought i'd add that in.
https://www.sau.com.au/forums/topic/95241-my-artwork/#findComment-1736105
  • 1 month later...
  • 9 months later...
    • Thanks for the explanation, I'll sleep a little smarter tonight! Cheers.
    • Being this happened about 4 years ago, i honestly forget exactly what is was, but I wound bringing to Simon at SR Werks when he was here in NY. He was able to properly diagnose and repair. I believe it had to do with the harness behind my dash.
    • It's because the air comes in over #3 & #4. The two "dead" ends of the plenum are at #6 & #1, with #6 being a little more "compromised" (Sorry about all the quote marks) than #1, due to the shape. So you get the dead end effect at #6 & #1 where dynamic pressure converts to static pressure, likely causing the air flow to be highest for these. The others are then just working in from the ends to the centre. 6 -> 1 is only valid for FFPs.
    • Cut back on the attitude champ, no one is obligated to help you. The chances of Forester owners on here are quite low, considering this forum is called Skylines Australia. https://www.subarupartsdeal.com/parts/subaru-under-cover-front~56410sa000.html ^ that picture looks wrong, because if you see the diagram, 56410SA070 looks correct. You can always check where the mounting holes are on your car, and compare them to the pictures.
    • Hey Duncan, I've always set them up from 6 -> 1. Due to slightly higher EGT's, I also add a small amount of fuel to cylinder 6 & 5. I understand why you start at 6 but curious as to why you then continue somewhat based on firing order? Thanks
