Don't Take Your Mum's New Camry To The Track.
  • Replies 51
Ohhhh!!!! So *THIS* is where I've been going wrong!!!
You're supposed to downshift AFTER corner entry and straighten up your line BEFORE the apex and then jerk the steering wheel back.
He just didn't do anything when it started to let go!! ahaha.
LOL - that's exactly what I was thinking when I watched it. He may as well have been sitting in the passenger seat once he lost it.
Also had to laugh as I have that exact same helmet, so it's a bit of a worry!
yeah this has been posted a few times since it happend. I think his main problem was he took two big bites at the corner, and down shifted mid corner for some reason. I actually feel sorry for the poor guy, i mean he was at a driver training day. he just made a mistake due to his inexperience and was unlucky enough that there was a pond on the inside of the track. i still don't know what track they were using as that's the issue i have. it doesn't look very safe at all. it looks more like a road with some witches hats randomly placed...
Bo hoo hoo i lost mummys car in the itty water.Lol.
He downshifted/ or poped the clutch mid cnr,but only after the car was allready in a slide,which was probably started from the wrong gear selection and not enuff brake in the first place. :P
Cant wait to meet up with you guys in a few weeks and put some names to faces.I just had the blue slip done so!!!
Let me tell you.It was allot of faRt asSing arrounD.
That pond would have done less damage than a concrete wall trackside. He would have written off the car and compacted it into a cube had he blindsided a concrete wall instead of having that run-off area and a pond to slow him down :lol:
Dry off the car, use a borescope and make sure no water was ingested and his mum would never know the difference :P
yes that's for sure! My friend would agree. he lost control of his GT3 cup car at turn 1 EC and i'm sure would have preferred a qucik bath as opposed to the concrete wall he hit. but my point was that place didn't really look like a race track at all. there were close trees lining the outside of the first corner. it just didn't look right.
It's Darlington Park, QLD... and yeah, it's a Corolla.
I feel sorry for the guy, he's taken it to the track to try and learn more, and obviously has made a mistake and then panicked.
It's very easy for easy to see exactly what he did wrong from the comfort of our computer chairs (or couches if you've got wireless :P), but in the moment, i'm sure some of us when learning to drive could have made the same mistakes, especially if we panicked.
Cheers,
Tommo.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
