Don't Take Your Mum's New Camry To The Track.
hmm so his mistake was that he downshifted at high speeds around a bend?? Or the fact he went to fast into the corner? hmm ..
it's a combination, he got to the corner too fast and was then lifted off the throttle mid corner to down shift which generated a fair whack of lift off oversteer, he tries to correct a little but at that point seems to be hard on the brakes which in the massive slide he is now in means he has no traction to alter the cars angle and bascially just slides into the pond. :P
  • Replies 51
lol handbrake is gold, i just realised that if this vid matches that outside shot (it must!) then this qualifies for WELCOME TO LAST YEAR
Yeah it's defintely an old video :P
99% of SAUers would do exactly the same thing, or worse, as they have 100 more hp at their disposal and probably less talent. :)
Bit rich to sit back and bash the guy with your keyboards.
After he lost it he did the right thing...on the brakes!
I reckon good on him for having a go and not just modding his car with bullshit bling and acting like you are the long lost love child of fitty cent and paul walker...
who care its a gold video
wish i had one of when i nailled the wall at the track
all that money wasted and nothing to show for it
just ask duncan he has it on video
if i did i would have a small tv dedicated to playing it over and over again!!!!!!!!!!!
haha ill see if I can dig up the video...got in my hdd somewhere...
its a guy named russell going around wakefield in his red wrx..and some hillarious commentary to boot...
I'm holding out to see it!
Impressive.
I would have thought a badly-done downshift would have compression locked the front, causing that to wash out instead.
But at the same time unbalancing the car mid corner, big no no... heal and toe!!! :P
Here's the thread - unfortunately it doesn't look like the vid is still up  :(
What about the brakes Russ?
Starts around post #34.
Did anyone save a copy?
yeah I saved a copy......but I dont know how to upload videos on to this forum.... :(
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
