heres lastnights effort at the motorplex first time out with this setup
R32 GTS-4 rb26det with 572rwbhp
ET:11.003
MPH:130
60':1.813
FUEL:BP ultimate
TYRES SAVA on the rear and FIRESTONE on the front
Nice time mate.
572rwbhp???
Do you mean 572 flywheel HP?
What power does it make at the rear wheels on a Dyno?
https://www.sau.com.au/forums/topic/95260-gts-4-rb26/#findComment-1723629
ET:11.003
MPH:130
60':1.813
FUEL:BP ultimate
Yeah!
https://www.sau.com.au/forums/topic/95260-gts-4-rb26/#findComment-1724138
Excellent work! Congrats. When are you planning on going for the ten? What are some specs on your combination?
ive gotta get some decent tyres before i go back.
its a 32 gtr engine with 33 crank,hi octane engine kit rods, pistons, grex oil pump, hks head gasket, tomei 270 cams 10.8mm lift, tomei springs and retainers and cams wheels, hks style staino manifold with PT67GTQ turbo from USA and 50mm HKS gate. it runs power fc djetro computer. 100mm hybrid coola im sure theres plenty more that ive forgotten.
https://www.sau.com.au/forums/topic/95260-gts-4-rb26/#findComment-1736554
    • My purchase experience was no where near as glorious as yours but still a significant moment in my life! Yeah that's a bit of a dilemma as to whether you bring it back or not!  Obviously a massive waste of time and effort to bring it back if you're only going to move there anyway!
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
