QLD UNOFFICIAL CALENDARS.
They are a professionally printed A3 calendar featuring a 250GSM Gloss Cover and 175GSM Gloss Pages.
Final ARTWORK (apart from the collage/rear cover) should be competed this arvo, so I'll post it up over the weekend.
Keep an eye out for it.
FINAL ORDERS WILL NEED TO BE PAID FOR BY THE 6th AT THE ABSOLUTE LATEST> i'll order on the 7th.
Hopefully a 10 day turn around.
So get you $$$ to me.
They will be $25 each.
MRR34 x4 PAID
AzzurA x1 PAID
Gts25t4door x1 PAID
JLnewton x1 PAID
R33Skyliner x1 PAID
Genesis x1 PAID
Jaqule x1 PAID
Chaos x1 PAID
SKA x1 PAID
Wrxkilla x2 PAID
Liam x 1 PAID
Col-GTSX x1 PAID
twoquick x1 PAID
95SKY x1 PAID
n15m0 x2 PAID
Rhinorbel x1 PAID
Slamm x2 PAID
Silver_R34_GT-T x1 PAID
SMR33 x1 PAID
3lit3 32 x2 PAID
Willo x3 PAID
impact_blue x3 PAID
Revhead x1 PAID
shaneo81 x1 PAID
Alfadog x1 PAID
Dangerous_daveo x2 PAID
Squizz x2 PAID
Penfold x1 PAID
BelGarion X1 AWAITING CONFIRMATION
https://www.sau.com.au/forums/topic/95287-sau-qld-calendar-orders/
  • Replies 54
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
