Gb: R33 Gts-t And Gtr And R34 Gtt Radiator Guides
  • Replies 520
the gtr seems to be a more refined product with proper mounting points and radiused edges. is that the finished item for the gtst?? so the only mounting points are the 2 centre drillholes in the pic?
cheers.
Hi Pete,
Just had another look at my grille and was wondering if there was a different one for the Series 2 R33?
Here's a dodgy snap of mine. You can see that this is different to Ruffel's grille as this one has no top edge bit. If that radiator guide were to be used here, I'd think it would look a bit funny as it doesn't finish on an edge.
Edited by lordsnipe
Hey guys.
The GTS-T guide will be modified before cutting to have the radiused edges and all that, and I'll make sure to post 3D images of it before I do.
The R34 GTT guide mounts through only two holes which also hold the bonnet latch.
The R33 GTR guides require a fair bit of work to get on and off as several bits have to be removed to go through the holes and slots.
Whereas, the R33 GTS-T has cut outs for these bits.
I was actually going to remove the holts and slots and make cut outs in the R33 GTR, but thought I'd just leave it as it is and you can cut the holes out easily yourself if you wanna make it easier to get on and off.
I will have a look at extending the GTS-T guide a little but not sure whether it will work on both S1 and S2 cars.
But with those pics you get a better idea of how it looks and sits.
Lordsnipe.
I checked the R33 GTS-T guide on several cars at the BBQ and it fit all of them, even those with custom bars, so you shouldn't have a problem.
CHEERS
BASS OUT
quite sure.
you can read back in this thread and its been answered...the guide attaches to the front of the support, whereas the snorkel sits on top of the support and isn't restricted what so ever.
My account details are below.
Peter N Blythe
Bank of Melbourne / Westpac
BSB: 733382
ACC: 586817
Amount $100
Transaction detail: Guide - 'username'
So the word guide and your username, or as much of it as you can fit.
So far only 5 people have paid......
Hey Nate.
don't worry, I haven't forgotten about you.
Gotta finish these grouop buy before I'm going to have a chance to make yours, but I will get there!
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
