Gb: R33 Gts-t And Gtr And R34 Gtt Radiator Guides
Hey ppls.
I'm extremly sorry about delay with group buy.
I've had a lot of life changes in the mean time but I digress.
The R33 Series I, Stag Series I, R34 GTT (all) guides are all being cut at the moment.
I have the cardboard boxes for freight in the factory and I will begin making them up shortly.
The R33 Series II guides are STILL not finalised but I'm doing some grinding on it today and I need somebody who can come ot Dandenong to trial fit it. I'd come to you, but I need to use a grinder to make any mods and the factory here has all that stuff.
The Stag Series II guide sample will be send out to two guys in Canberra to fit to their car and try it out. I think it should be pretty good, but it may need some slight re-modelling.
Again, I'm super sorry about the delay, but understand that I will supply each and every one of the guides as soon as I can.
I thought I'd be able to finish them a lot faster than I have. I've had a lot of stuff go on in the last few months. It's been crazy.
Yours in total apology
BASS
  • Replies 520
Hey,
I'll DEFINATELY take one for an R34 GTT with a Nismo front bar!
Let me know as soon as you need money for it + freight and ill transfer!!!
PM / Email / Phone me if you need to!
Thanks.
Hey ppls,
Just got the phone call and went and picked up the blanks.
So, I have all the Series II Stags, the Series I R33, all the R34 guides in the back of my car.
I'll be testing a revised R33 Series II guide on a car on the weekend and a Series II Stag also.
The end of this group buy is nigh. Finally. :S
Cheers
BASS OUT
R33 Series II guide modified.
It's been ground and the bend changed and will be trial fitted again to Dezz's car on the weekend.
Hopefully she'll be all good this time.
Cross your fingers.
These are still available Bass? I'd like one for my R34 GTT... think it's a standard nismo front bar. Could you pm me the details? Cheers.
Bass Junky or Dezz, any updates on how the fitment went?
I know there have been problems but one more month and this has been going on for a year, and payment was in Feb! That was 8 months ago! It's getting ridiculous.
Hi Guys.
Again, I sorry about the delay. I have not stopped on this bloody project.
I took the guides to a plave near here last week and went back a few days later and they then told me they couldn't do it because they are too busy and blah blah blah.
So shortly I'm going out to find antother person.
I'm also playing with Dezz's car tomorrow.
Stay tuned.
TOP NEWS PEOPLES
I have finally trail fitted the R33 GTS-T Series II guide to Dezz's car and lo and behold, it's spot on!
A very minor adjustment to an angle and she's apples!
I'll be sorting out hte order to the laser cutters on the next day or two and then away we go.
THANK YOU EVER SOO MUCH FOR YOUR PATIENCE.
Bass Out
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
