Gb: R33 Gts-t And Gtr And R34 Gtt Radiator Guides
  • Replies 520
I finally fitted mine up last weekend it looks great. One thing one of the mounts for my oil cooler has a screw hole along the top edge is there a simple way to drill another hole through the metal or should i just leave the top mount for the cooler unbolted like it is at the moment.
Okay, SII.
the guide was originally drawn in one package, and to modify it the way we want to, we are going to have to redraw it in another format.
this will probably take about an hour, and then I have to get the final sample cut.
Soon. I really really sorry for the delay.
hey ppls.
I'm back from Broome now.
I'm sending out the final samples of several of the guides Monday.
Should have final, 100% version of all guides (expect R34 GTR) this week.
My first priority will be the Series II R33 guides.
BASS OUT
BASS OUT
THATS ME!!!!!!!! and ive got my car back now :P
I can probably pick it up from you at D4D pete...dont forget adonised black :P
Guest
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
