Gb: R33 Gts-t And Gtr And R34 Gtt Radiator Guides
Gentlemen, I'll be away on Holidays tomorrow. I'll be back on the 12th of December.
I'll be starting the prototypes then and I should have something to show soon after.
Cheers
BASS OUT
  • Replies 520
Hey guys.
The sample cuts didn't get done before Christmas, but should be ready real soon.
I'll keep you all in the loop.
BASS OUT
Would Like to get 1 for a Series 1, R33,
isit series 1? or 1.5?
not sure, 95'
stock front bar, (I think)
will get pic up asap.
I prefer it to be black? what is the best way to get it?
DIY paint job? :(
nice,
Look like my engine bay gona get some *bling *Bling,
hehehe
Thanks paul,
Yea I fink DIY pain job should be the way to go, coz atleast u know u f*** urself up, not some1 else, Or NOT : :lol:
That was acutally me sending that, but Paul was logged into my comp last night, and I forgot to log him off.
I oul suggest Anodising. beautiful finish.
I might actually offer it as a package in black or Silver....
Maybe
One of each for R33 GTR and R33 GTSt mate. Disgusted I wasn't automatically added. The povo R33 GTSt auto can bloody go without though :)
Guest
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
