Hey all,
I was cruising throught the Prestige Motorsport stock and came up with thisToyota Aristo. They run a twin turbo six, but not the wimpy 1JZ like the chaser - they get the full 2JZGTE treatment! *Insert Fast n Furious quotes about engine here*
Compliance is still about 8 months away apparently, but I think 4-Door Skyline and Stagea owners better look out - family man in a hurry has a new weapon!
The crazy part is that one on Prestige is for sale for LESS THAN $11,000!!!!
Maybe I should upgrade my R32 4-door for one. I was considering the UZZ31 Toyota Soarer and R34 Nissan Skyline Sedan as an upgrade, but I think the Aristo has joined the list!
What do people reckon?
https://www.sau.com.au/forums/topic/95291-toyota-aristo/
I wouldn't take an 11k example as the 'average'.
I emailed Geoff and he said that yes, this one is particularly cheap. Typically the Aristos start at around $13k, which is still a bargain in my mind! :angry:
prestige always does that
You say that like it's a bad thing! Surely advertising cheap cars on the Prestige website should be encouraged not looked down upon :P
I got some additional information:
Twin turbo JZS147 2JZ-GTE 3lt 206KW/1680kg IL6 Engine -122kw/tonne.
Non turbo JZS147 2JZ-GE 3lt 169kW/1580kg IL6 Engine - 107kw/tonne.
4WD UZS143 1UZ-FE4ltr 191 kW/1740kg V8 Engine -109kw/tonne
Sunroof and Leather are uncommon options, and ALL were sold as automatics. The only manuals are aftermarket jobbies.
https://www.sau.com.au/forums/topic/95291-toyota-aristo/#findComment-1724551
Well i don't know, they just seem to pick a couple out there which are that lower price to 'bait' people, then when people ring because of the low price, that car has been snapped up 'but wait, we have more we can get access to'.
It's a standard business practice, but you know :P
Edited by predator2
https://www.sau.com.au/forums/topic/95291-toyota-aristo/#findComment-1724561
chris, that's the newer aristo, the one everyone likes... the one in the first post is the old one... mechanically/technologially cool, but a bit lacking cosmetically.
https://www.sau.com.au/forums/topic/95291-toyota-aristo/#findComment-1725520
Gueses on what youd get the v300 for? yeh the lexus 2jzgte
my "man the jza80 is nice but it sure looks bling bling" worries are over. Im saving right now for this.
http://www.lexusvertex.com/aristov300_spec.htm
still prolly handles like a whale and is slow oof the line but it would make a great freeway cruiser.
Edited by Boostzor
https://www.sau.com.au/forums/topic/95291-toyota-aristo/#findComment-1726938
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
